Old 18-Apr-2016, 3:48 PM   #1
hsparks56
2 Antenna's and grounding advise
Need advise on the following: Do I need a separate ground wire for 2 antenna's that will be mounted about 15 feet away from each other or can I jump a ground wire to the other and then to my service ground?
hsparks56 is offline   Reply With Quote
Old 19-Apr-2016, 2:16 PM   #2
rickbb
You can jump the grounding wire no problem assuming you mean a mast grounding wire and not the coax grounding block(s).
