Old 14-Apr-2016, 12:49 AM   #1
smyrna-ga
Question Help for home in Smyrna, Ga
http://www.tvfool.com/?option=com_wr...5134c9b6d1bd3a
Hi tvfools:
I would like to provide free TV to my guests.
I've tried indoor antenna and some channels were gr8, but I had to make adjustments often. This is not idea for guest and I would like to have a system in place that provides clear free-to-air channels for 3 TVs.
Any suggestions on type of antenna and components, installation, ... would be greatly appreciated.
Thanks heaps..
smyrna-ga is offline   Reply With Quote
Old 15-Apr-2016, 1:37 AM   #2
Welcome, Angie:
Where can you put the antenna, indoors, attic, or outside?
Are you thinking of one antenna to feed all TVs, or an antenna for each?
Your signals are fairly strong and in the same direction from the SE but you are behind a hill. You shouldn't have too much trouble unless there are trees or other buildings in the signal path.
PBS and ION are your weakest signals, and ION is in a different direction, which is a complication.
Old 18-Aug-2016, 8:45 PM   #3
smyrna-ga
Question Antenna type and location help request
Thank you Rabbit73,
Answers to your questions.
No restriction on where to install an antenna.
Probably one antenna if that's the better option. Open to suggestions.
There are trees everywhere, is there a way to obtain info so I can provide accurate details?
Complicated meaning additional hardware, more expensive or ?
Suggestions on what type of antenna, equipment, and installation .... would be very very appreciated.
The installation window I have available is from 31-August to 4-Sept.
new report http://www.tvfool.com/?option=com_wr...e2cb5beb83ae4a
Thanks a million
Angie
Thanks so much.
Old 18-Aug-2016, 9:30 PM   #4
Hi, Angie; welcome back.
Most of your channels are UHF, but NBC is on real channel 10, so you need a VHF/UHF antenna like the Winegard HD7694P mounted outside as high as you can get it. The antenna should be aimed at about 135 degrees magnetic.
ION will require a separate Antennas Direct DB4e antenna aimed at 348 degrees magnetic and a custom combiner to add it to the other channels. Maybe you can do without ION for now.
If you are willing to provide your exact address or coordinates in a PM I can look at the satellite view of your location.
Because of the hill in the signal path, I suggest making a test with just one TV, and then add a 4-way splitter for more TVs. If the signals are too weak, replace the splitter with a Channel Master 3414 distribution amp.
Old 19-Aug-2016, 2:21 AM   #5
Thank you for the additional information. I will study it and post again.
At first glance, I am worried about the trees and the hill in the signal path. But the fact that you have had some success with an indoor antenna and the tvfool report is often not very accurate with 2Edge signals, is encouraging.
Old 19-Aug-2016, 6:37 PM   #6
I looked at an aerial photo of your location. The green signal lines miss the trees across the street, but I'm worried about the trees in front of your house.
Is it possible to install the antenna with a telescopic mast?
Yes, a telescopic mast can work if the antenna is located where it can "see" between the trees and below the branches in front of your house. Trees block TV signals.
Scroll down to Trees and UHF
Old 19-Aug-2016, 7:07 PM   #7
You can see the terrain profile between a transmitter and your location if you click on its callsign in your report. The transmitter is on the left, and your location is on the right.
WXIA NBC
http://www.tvfool.com/?option=com_wr...dALLTV%26n%3d3
WSB ABC
http://www.tvfool.com/?option=com_wr...ALLTV%26n%3d10
The signals skim the last hill.
That hill doesn't look too serious; I'm more concerned about the trees.
If you have an incoming overhead power line, keep the antenna away from it for safety.
Old 23-Aug-2016, 1:48 AM   #8
This photo shows the green signal lines from the SE. They clear the trees across the street, but I'm worried about a clear path through the trees in front of your house. You might have to trim some branches.
Old 19-Mar-2017, 8:28 PM   #9
smyrna-ga
hiya rabbit, its been a long time and I really want to thank you for all your support on this.
I didn't have a chance to get the antenna installed before having to head back to Sydney last year but I'm looking for someone to do the install and take some photos.
So again, THANK YOU SO SO SO MUCH!!
Old 20-Mar-2017, 7:57 PM   #10
Thank you for the update. I was wondering how it was going, as I usually do when I give advice.
Best regards,
rabbit
Tags
antenna advice, equipment recommendation, installation, smyrna ga, system setup
