Old 25-Oct-2015, 7:18 PM   #1
hunterleej
Just getting started
I would like to save money on my cable bill. I presently have cable tv with a box, internet connection and my phone land line all with the same company. Being a total beginner, I don't which if any of those I can get rid of. I certainly would appreciate some guidance. My report is as follows.....
http://www.tvfool.com/?option=com_wr...8e037cf5ce5de0
Thank you very much
hunterleej is offline   Reply With Quote
Old 25-Oct-2015, 7:37 PM   #2
Try an ANT-751 on the roof aimed at 219 degrees. Unless you have more than 2 TVs a preamp or distribution amp is not necessary. You'd get a full slate of networks.
Old 25-Oct-2015, 7:45 PM   #3
hunterleej
Ant-751
will it have instructions, etc that will show me how to point it to a certain degree?......keep in mind that I'm new at all this stuff....Thanks
Old 26-Oct-2015, 12:35 AM   #4
Tim
Use a magnetic compass to aim the antenna towards the stations as show in the attached picture. You can find an inexpensive compass at Wal-Mart or stores that sell camping gear.ant751.jpg
Old 26-Oct-2015, 9:49 AM   #5
hunterleej
Ant-761
Thanks Tim........when I wire the ANT-75.......do I bypass the cable company box and wire it straight to the TV? I've got a Sony HD TV that is about 8 years old and a smaller newer smart tv in another room...Am I ok with those? The sony is my main tv.
Old 26-Oct-2015, 10:20 AM   #6
lets go red
Yes, connect the coax from the antenna directly to the TV and do a channel scan (Don't drill any holes yet). Make sure you choose antenna or air, NOT cable, in the settings before starting the scan. It might be advantageous to use the newer TV for the initial scans and aiming as the tuner could be of a newer generation.
After the antenna is up and working you can easily add a splitter etc. for a second TV.
DO NOT use any cable co. supplied boxes with OTA as they are designed for cable frequencies and authentication.
RCA ANT-751 on Amazon: http://www.amazon.com/RCA-Compact-Ou.../dp/B0024R4B5C
lets go red is offline   Reply With Quote
Old 26-Oct-2015, 11:58 AM   #7
hunterleej
Ant-751
Thanks Let's go red.....I'm sure I'll have more q's before I'm done.
