Old 25-Apr-2015, 8:23 PM   #21
Jake V
Check your direction. I just looked at your TV Fool Report. Earlier I noted 167 degrees for ABC (Real Channel 13 - VHF Hi). But I see I was mistaken. It's 154 degrees magnetic. Try re-aiming it. Also try a few inches up and down the mast. Sometimes an inch can make a huge difference.
Old 25-Apr-2015, 10:43 PM   #22
Eldrick
Thanks!
Will try.
Eldrick is offline   Reply With Quote
Old 7-Jun-2015, 11:36 PM   #23
Eldrick
Back again. No luck with ABC. I will try fiddling more in the future, but I only now realized that I don't get the CTV local. This is a VHF station broadcasting about 7 miles from my location. My antenna is pointed at about 150 degrees, this station os off the back at 312 degrees.
I am not higher than the house, so it is blocking - but all other locals come in at 100%, but they are UHF channels (I think).
If I am above roof line should I get CTV, or is this how directional VHF band is?
Thanks
