Old 5-Jun-2015, 12:56 PM   #21
The Antennacraft 10G202 is a high-gain amp that is relatively easily overloaded. AC's own website includes this advisory: "Best used in deep fringe areas where all signals are weak."
See post #2 for appropriate recommendations.
Old 5-Jun-2015, 3:18 PM   #22
PCoaster
No, no aircraft to cause the issue.
PCoaster is offline   Reply With Quote
Old 5-Jun-2015, 4:09 PM   #23
PCoaster
no, no aircraft to cause the issue.
Old 5-Jun-2015, 5:42 PM   #24
PCoaster
No, no aircraft to cause the matter.
Old 5-Jun-2015, 9:36 PM   #25
I don't have your exact address, but I think this FMFOOL report is more accurate than a zip report. It shows WBHQ 92.7 MHz 2.1 miles away at -18.4 dBm; attachment 1. I think an FM filter is called for to prevent interference, even if your preamp has one.
The RCA and the Juice preamps are more resistant to overload than the Anntennacraft 10G202. The RCA has an FM filter, the Juice doesn't. Put one or two in series between the antenna and the preamp input. Your strongest FM signals are 92.7 and 98.7 MHz. All FM filters are not equal (see attachment 4), but you have a choice based on those frequencies: Antennas Direct, MCM, and Radio Shack.
http://comingsoon.radioshack.com/rad...l#.VXIu6zjbJLM
You can also use a HLSJ as an FM filter, connecting to the high and common ports. It rejects everything below CH 7, including the FM band and has low insertion loss:
http://www.hollandelectronics.com/ca...-Diplexers.pdf
And I see a lot of trees, which are the enemy of UHF signals; attachment 2.
scroll down to Trees and UHF
And I see a highway that the signals have to cross; attachment 3.
(I also see an airfield, but we covered that.)
I am aimed at about 165 degrees (pointing south) I am just using an iPhone compass and standing under the antenna to guesstimate the placement.
176 magnetic with a real compass would be better.
Tags
antenna advice
