Go Back   TV Fool > Special Forums > TV Fool Discussion / Database Updates
Old 14-Jan-2015, 3:01 AM   #1
Dick9clark
Help I am in the sticks near Pittsburg KS and Joplin MO
Here is my location. I was thinking of a combined UHF and VHF for one antenna and another for the Single station in the other direction.
http://www.tvfool.com/?option=com_wr...2c15623dd8d099
Thanks
Dick9clark is offline   Reply With Quote
Old 14-Jan-2015, 1:21 PM   #2
Jake V
1. This post belongs in the "Help with Reception" forum below.
2. Your TV Fool Report is only resolved to the block level. It is probably reasonably accurate for your location but you can make it more exact by following the directions at this link: http://forum.tvfool.com/showthread.php?t=14508
If your TV Fool Report doesn't change for your exact address you're going to need something pretty powerful (you have a lot of 2 edge, weak signals). And you have one VHF-HI Station (7-CBS) with the rest being UHF. A single antenna solution like the HBU-55 aimed at 165 degrees might not get the PBS station at 164 degrees (KOZJ-25).
But re-post below in the correct forum with an updated TV Fool Report for an expert recommendation.
Old 16-Jan-2015, 12:02 AM   #3
Dick9clark
Thanks for you help . I will
