Old 4-Aug-2014, 10:10 PM   #1
Dallasgirl
Moved and need another OTA
Digging up this old thread. (http://forum.tvfool.com/showthread.php?p=45491), I have since moved and need help with a new antenna. Here are my details.
http://www.tvfool.com/?option=com_wr...e1c65292b2c3cd
I would like to place in the attic if possible.
Btw I love cutting that cord!
Thanks in advance,
Jill
Dallasgirl is offline   Reply With Quote
Old 4-Aug-2014, 11:11 PM   #2
A Simple Reception Situation.
Attics and the Inside of Buildings Are Not a reception friendly location and Never Will Be a reception friendly location.
Yes you can install a ,
http://www.antennacraft.net.
HD850 antenna in the attic aimed at about 235 degree magnetic compass direction.
A antenna system amplifier is not required.
If reception situations happen in the attic that are not resolvable with antenna aim adjustments and antenna location adjustments in the attic , then move the antenna to above the peak of the roof.
Old 13-Aug-2014, 1:38 PM   #3
Dallasgirl
Teleview: I will look at that Antenna.
Thank you!
Old 13-Aug-2014, 2:12 PM   #4
Dallasgirl
Oh if I choose to split to 4 tv's do I need any additional equipment?
Thanks again!
Old 13-Aug-2014, 2:32 PM   #5
tomfoolery
If size is an issue, and/or if you don't care about real 2 and 4 (infomercials and off the air, per rabbitears.com), an HBU33 has the same gain on UHF and slightly more gain on high-VHF. Just another option. The HBU33 is 43-1/2" wide and the HD850 is 111" wide, and both are 85" boom length.
tomfoolery is offline   Reply With Quote
Old 13-Aug-2014, 3:03 PM   #6
Dallasgirl
Interesting....a quite a bit smaller in width, lighter and cheaper.
Thanks for the alternative. I will check that one out too.
Old 13-Aug-2014, 4:16 PM   #7
Stick with the narrower antenna. There's nothing on the air in Dallas that requires the wider one.
Old 13-Aug-2014, 9:06 PM   #8
As I understand it. It is not my place to tell Dallasgirl what is of interest for Dallasgirl to receive or not receive.
I see that others here at Tvfool , see it as their place to tell Dallasgirl what Dallsgirl can and can not receive.
Dallasgirl , might like to receive.
KHFW-LD low band Tv channel 4 , infomercials.
KSFW-LD low band Tv channel 2 , Religion programing.
The HD850 antenna is designed for reception of--> All Tv Channels.
Both of these Tv stations are for sale.
As is-->true<->of other Tv stations here in the USA and around the world are for sale.
The New Owners will most likely change the Network programing to some other Network/s , as often happens when Tv stations are sold.
The Network/s on the Tv/s stations may or may not be of interest now and the Networks may or may not change to something of more interest.
Last edited by teleview; 15-Aug-2014 at 8:21 AM. Reason: Clarify information and typos.
