Old 3-Jun-2014, 12:51 PM   #1
bobham1466
Antenna Reccomendation
Below is a link to the TV Signal Analysis at my house. Exact coordinates were used because the system didn't recognize my mailing address.
http://www.tvfool.com/?option=com_wr...e1c611a779e76b
I just cancelled my DirectTV service and i'm wondering if mounting an outdoor antenna on the existing j-pole, and using the existing coax is a good idea or not.
~Bob
bobham1466 is offline   Reply With Quote
Old 3-Jun-2014, 5:07 PM   #2
Stereocraig
You should be OK w/ the J pole, as long as it's high enough to clear any obstructions.
The coax should also be fine if there are no switches in line.
Any other recommendations, will depend on which channels you want, length of run and number of sets.
