Old 13-May-2014, 8:55 AM   #1
Pontiack5
Are these low numbers worth a try?
Hi to everyone. I've been reading this site for a long time trying to learn. I'm in the corn belt, flat farm land. I'm fed up with Mediacom.
I'm considering an XG91, DB8e or HD4228 antenna simply based on what I've read. I'm thinking a PA 18 preamp. I suspect a rotor is necessary, but there seems to be a lack of quality as to what brand is the wise choice. My limit is height. I have to have a roof mounted antenna on a two story. 25 to 30 feet is about as high as I can go. This is my first post, so hopefully I'm entering correctly. Any suggestions, comments, or information is appreciated. BTW,I know the VHF channels 9 and 10 are on the list, but I'm not especially interested in 10. I may add WILL VHF in the future, provided there would be a real chance it would work. Do I Have a chance with these distances and low numbers at receiving anything?
Pontiack5 is offline   Reply With Quote
Old 13-May-2014, 9:45 AM   #2
Please make and post a , tvfool radar report and channel list.
Use the Exact address to make the tvfool report.
Make the antenna height above ground in the tvfool report 25 feet above ground.
Old 13-May-2014, 3:47 PM   #3
tonyp063
We'll need your TVFool report to give you any suggestions.
Please go to
https://www.tvfool.com/?option=com_wrapper&Itemid=29
And put in your actual address. Set the height to 25 feet.
Then put the URL you get that will link to the report (don't worry. Your actual address information wil be obfuscated for privacy)
Once you do that we can see what may or may not be possible & on what bands the stations are broadcasting to make a suggestion for you
tonyp063 is offline   Reply With Quote
Old 14-May-2014, 7:17 PM   #4
Pontiack5
I've been trying. Here is the info: http://www.tvfool.com/?option=com_wr...de1c6815fb7f69 I hope this going to work.
Old 15-May-2014, 7:11 PM   #5
Pontiack5
My TV Fool report is working. Any suggestions?
Old 15-May-2014, 7:16 PM   #6
tonyp063
The reply you got in this thread
http://forum.tvfool.com/showthread.php?t=14490
is good. I'd suggest that.
Adding a rotor introduces additional problems. Difficult to manage if you are driving multiple TVs.
You have to rescan for channels every time you rotate.
Old 15-May-2014, 7:47 PM   #7
Pontiack5
Thank you. I had a little trouble posting. I'm using one TV. The reason I'm asking about the rotator is I was wanting the Champaign and Decatur stations. They are southeast. Those Peoria stations have so many infomercials they are annoying. I thought I might have an alternative when this happens. WCIA is more of the local station for news and local programs. I'm just looking into options. I believe that preamp is at our Walmart. Do you think WCIA and WAND are also doable? I'm in the FCC contour mmap circle by about block. I just want to get a good idea before I buy this weekend. Thanks again for helping me out.
Old 16-May-2014, 9:13 PM   #8
tonyp063
The only way to tell is to try. Those stations are going to be a boarderline case. Awfuly low noise margins.
Were it me, I'd go with just the antenna to start & aim it at them to see what happens, for a test.
You can always add the rotor later.
Old 17-May-2014, 11:46 AM   #9
Stereocraig
Some TVs allow you to ADD channels, VS a complete rescan.
I.E. Sony Bravia.
