Old 6-Feb-2014, 4:32 PM   #1
dghouse
Missing Station
I generated a report for my home
http://www.tvfool.com/?option=com_wr...5b94f394874778
but it does not include the local CBC station. The information for that can be found here:
http://en.wikipedia.org/wiki/CBNT-DT
Is there any way I can add this to my report or does it need to be added by a site admin?
Thanks a bunch!
dghouse is offline   Reply With Quote
Old 6-Feb-2014, 4:35 PM   #2
dghouse
Sorry, total newbie mistake. I found the link on the page...
http://forum.tvfool.com/forumdisplay.php?&f=19
Old 6-Feb-2014, 5:08 PM   #3
The , Current Plus Pending Applications Included Tvfool Report is what I Reference.
The provided tvfool report is not showing any antenna height above ground.
Do not delete the the report that is not showing any antenna height above ground.
To see if any more Tv stations will be received , please make and post 3 more Tvfool reports at , 25 , 40 , 60 , feet antenna heights above ground.
For Accurate reports of your reception location please use your Exact address to make and post reports.
If your exact address does not work.
Then go to the Tvfool home page and Click On , >>Start MAPS<<.
Select a location as a starting point , and Move The Pointer to your Exact Location.
Make and post the Tvfool reports of , 25 , 40 , 60 , feet antenna heights above ground.
Last edited by teleview; 6-Feb-2014 at 11:46 PM. Reason: Clarify information and typos.
Old 6-Feb-2014, 6:29 PM   #4
Here is a way to receive All of the PBS Network channels for free and other Network Channels for Free.
FTA-ST = Free To Air Satellite Tv.
FTA is can be received in , Canada , USA , Mexico , and All Around the World.
Here are some web sites to start to learn about FTA-ST .
www.ftalist.com
www.manhattan-digital.net
The next 2 web sites are in Canada.
www.saveandreplay.com
www.trentondistributors.com
The dish size for KU Band FTA , is Small dish size.
For Reliable Reception of KU Band Satellite Tv , use a dish size that is larger then the minimum size of small dish.
Old 6-Feb-2014, 6:35 PM   #5
You have to click on the button for 'Pending' since IC hasn't updated their database.
Old 6-Feb-2014, 6:57 PM   #6
dghouse
Ah, pending? Well that's odd, it is broadcasting. There's an analog station listed called CHCB. I don't know what that is, but they aren't broadcasting. Ah well, thanks for your help!
Old 6-Feb-2014, 10:54 PM   #7
Like I said, IC has not updated their online database from which TVFool pulls the data regarding operational status.
Blame it on the Canadian bureaucracy which is about as effective as the US version.
