Old 12-Nov-2013, 11:55 PM   #1
DeDe
Western Maine Reception
Here is the TV analysis for our place in western Maine mtns:
http://www.tvfool.com/?option=com_wr...46aec3d129ab30
Key things I know is want to get more channels, we get NBC, CBS and PBS and a local news/weather station, want Fox and more. I believe we need rotator because wind and weather gets rough during winter in Maine and no one will be climbing on the roof to alter direction. (however if you experts out there don't think necessary please say so, $ can be better spent) Pre-amp needed and splitter for hook up to 3 tv's, one on each level of house.
Equip I have researched and want to know if right for this job are:
Wingard HD8200U antenna or HD Stacker.
Pre-amp have no opinion on.
Rotator I'm sold on Channel Master 9521A.
Any and all guidance SO appreciated. Want to order asap and get this up before the snow flies.
thx
di
DeDe is offline   Reply With Quote
Old 13-Nov-2013, 9:34 AM   #2
Talking
The Tvfool report shows a antenna height of 30 feet above ground , do you have a way to install the antenna that high now??
A Big Strong antenna is required for reception.
Install a Winegard HD7698P antenna aimed at about 173 degree magnetic compass direction.
Install a Winegard, LNA-200 'Boost' XT , antenna system amplifier.
Buy the HFS splitters at , www.solidsignl.com.
www.solidsignal.com
www.amazon.com
www.winegaddirect.com
Last edited by teleview; 15-Nov-2013 at 8:34 AM. Reason: Clarify information and typos.
Old 14-Nov-2013, 1:38 AM   #3
DeDe
Hi, thx for input. Wondering why no comment to HD stacker antenna ot 8200u. The 8200u which has same dbgain as 7698 as seen on Wingard site.
HD stacker is an easier size for my husband to install due to stacking technology and is stated built for strong winds/heavy duty as is stated to the 8200.
I am trying to understand here.... 3 different forums/antenna suggestions have suggested 3 different antennas, all listed above. Costs are within $20 of each other.
Question is what truly are the differences.
Question: looking at gain charts on Winegard site the 7698 doesn't show dbgain for channels 2,4 and 6....but the 8200 does. If you can explain why much appreciated.
To answer question in reply, antenna is 30 ft up, house built into hill and side it is going on is walk out side, 3 stories up.
Again thx for any and all info!
Old 14-Nov-2013, 2:24 AM   #4
That's because the 8200 is a 2-69 antenna and the 7698 is a 7-69 antenna (it has no extra-long, 6-10', elements).
No one here that knows about antennas buys into Denny's sales pitch for the Stacker.
Based on the broadcast channels in use in your area, you don't need low-VHF channel reception. W04BS and W03AM are repeaters for WCCB with is easily receivable on VHF channel 10. The other VHF signal shown on channel 4 is too low of power to be receivable. That leaves you with a requirement for a long range antenna that provides coverage for channels 7-51 (or 69).
You can probably get a bit better performance out of separates rather than a 14' long antenna on your rotor. The most common combo is the 91Xg plus a 10-element high-VHF unit from Antennacraft or, if still available, Winegard. Add a decent two-input, medium gain pre-amp like the Antennacraft 10G221 or the RCA pre-amp and that's about as good as you're going to get.
Old 14-Nov-2013, 4:35 AM   #5
No requirement to install a All channel antenna such as the HD8200U antenna , W04BS-D channel 4 is a Very Strong Signal Strength local repeater transmitter and will be received by a antenna the does not have the long channels 2 thru 6 metal reception elements.
W04BS-D channel 4 and W03AM-D channel 3 are repeaters for WCBB channel 10 PBS.
http://www.en.wikipedia.org/wiki/Mai...asting_Network
WCBB and W04BS will both be received.
And W04BS-D , Is a Very Strong Signal Strength local Tv repeater and will be received by the HD7698P antenna.
And WGCI-LD channel 4 is to weak signal strength to receive reliably.
www.en.wikipedia.org/wiki/WLBZ
A , Hi-Gain AR 40 , antenna rotator is a Heavy Duty antenna rotator to use to , fine tune , the antenna aim direction if required for reception.
Can type , Hi-Gain AR 40 , in the , www.google.com or www.yahoo.com , search box to find a place to buy the Hi-Gain AR 40 antenna rotator.
www.hy-gain.com/Product.php?productid=AR-40 .
www.aesham.com
WPXT-DT Real UHF channel 43 , The CW Network and Me-Tv .
www.en.wikipedia.org/wiki/WPXT
and
WPME-DT Real UHF channel 35 , MyNetwork and Maine Vistor's Channel.
www.en.wikipedia.org/wiki/WPME
Are Very Weak Signal Strength Tv stations.
A big antenna with maximum antenna gain is required to reach out for reliable reception.
The Winegard , HD7698P antenna.
Here are some strong and sturdy above the roof antenna mounts.
www.ronard.com/909911.html
www.ronard.com/ychim.html
Measure around the chimney and use a , ronard(2212) , ronard(2219) , ronard(2224) .
Buy the ronard antenna mounts at , www.solidsignal.com , by typing , ronard(x) , in the solidsignal search box or buy from , www.ronard.com .
Last edited by teleview; 15-Nov-2013 at 8:37 AM. Reason: Clarify information and typos.
Tags
hd stacker, hd8200u, maine, pre-amp
