Old 21-Oct-2013, 1:27 AM   #1
sawdust1957
help with antenna
http://www.tvfool.com/modeling/tmp/4.../Radar-All.png
Trying to pull in all the stations that i can. I am thinking about a channel master cm-3020 antenna at about 40 feet high to see.
Would this be a good antenna or which one would be better.
You guys are alot smarter at this than me. thanks
sawdust1957 is offline   Reply With Quote
Old 21-Oct-2013, 6:00 AM   #2
The 3020 would give a chance at seeing some signal from WWWB if it actually comes on the air. The signal is quite weak for that part of the L-VHF band. The signal from WTVF is even weaker, well bellow that typically needed for reliable reception of a L-VHF signal. Fortunately the signal on real CH-5 is a translator signal and the primary signal is broadcast on real CH-25 which has far less interference.
I would opt for an Antennas Direct DB8e + Antennacraft Y10713 + RCA TVPRAMP1R preamplifier which has separate inputs for UHF and VHF antennas.
Old 22-Oct-2013, 4:17 AM   #3
Pratical and Useful Information.
Found a little information about WWWB Tv .
www.en.wikipedia.org/wiki/WMOR-TV
I do not think the information is correct.l
Last edited by teleview; 22-Oct-2013 at 2:18 PM. Reason: Clarify information and Typos.
Old 22-Oct-2013, 11:30 AM   #4
Wrong station. WMOR previously used the call letters WWWB for several years back in the 90s before changing them to the current.
There is no evidence that WWWB-LD is on the air. They filed an License to Cover in early 2012 then promptly filed a displacement app to move to channel 50. Smells like a zombie station or a frequency speculator.
Old 22-Oct-2013, 2:23 PM   #5
Practical and Useful Information.
So , sawdust1957 , what is WWWB??
Is WWWB on the air??
Why did you select WWWB??
Old 22-Oct-2013, 8:45 PM   #6
sawdust1957
Is WWWB on the air.
I dont know what station wwwb is as I have never pulled it in. I also believe it is off air.
Old 22-Oct-2013, 10:08 PM   #7
Install a Winegard HD7698P antenna aimed at about 271 degree magnetic compass direction.
Use a Real and Actual mgmetic compass to aim antenna.
Install a Winegard , LNA-200 'Boost' XT , amplifier.
Buy the HFS splitters at , www.sloidsignal.com
www.ronard.com/909911.html
Install the , ronard(911) , 5 foot tripod antenna mount.
www.ronard.com/34424560.html
Install the , ronard(4560) eave antenna mount.
www.ronard.com/ychim.html
Buy the ronard antenna mounts at , www.solidsignal.com by typing , ronard(x) in the solidsignal search box or buy from www.ronard.com
Here are places to buy antennas and etc. .
www.solidsignal.com
www.amazon.com
www.winegarddirect.com
www.ronard.com
