Old 21-Sep-2013, 8:27 AM   #1
jelwell
Antenna Suggestion in Boulder Colorado
My sister has had her apartment completely flooded by the recent Boulder Creek flooding. Management has a new apartment for her on the third floor, instead of the flooded first floor. She had been paying through the nose for cable tv, her provider is charging her for the replacement cost of her cable box and modem! So she's done with cable tv, not only is the monthly cost expensive, she's being reamed during a disaster.
Here's her report:
http://www.tvfool.com/?option=com_wr...46ae5ca95ffb0c
It looks like she can get ION, ABC, NBC, PBS and MyN with an indoor setup. I'm wondering with her being on the third floor if there's an antenna (that she can use indoors) that might help her pickup Fox, CW, and CBS.
She said she went to her local Radio Shack, and they told her that she couldn't get any signals with an antenna. She's in an apartment complex, so she's almost certainly limited to indoor setups. I'll post back later with what direction her windows face - perhaps that will help a bit.
Joseph Elwell.
jelwell is offline   Reply With Quote
Old 21-Sep-2013, 6:12 PM   #2
Do Not go to radio shack - for any reason.
Do not accept any information that the people at radio shack tell you , 99.9% of the information will not be correct.
_________________
---->Please answer this question. What directions do the , windows and balcony face??<----
Your sister has ->Many<- receivable Digital Broadcast Tv stations/channels at her location.
For a indoor type antenna , install a Terk HDTVi (not HDTVa) antenna in/at a ~ South ~ facing window or a balcony door window.
If a Long coax run through the Apt. is required to get the HDTVi Tv Reception from the HDTVi antenna to the Tv , then so be it.
Window glass , balcony-patio door glass , is less obstruction to broadcast Tv reception.
The building construction that is wood with wood or vinyl siding is more obstruction to broadcast Tv reception.
The following is a Non Complete list of building construction that is More obstruction to Broadcast Tv reception.
Concrete walls and building , concrete blocks , bricks , rocks , metal siding , metal walls , metal roof , metal backed insulation ,
apartments between your sisters apartment and the transmitters , other buildings between your sister apt. and the trasmitters.
__________
Aim the HDTVi antenna at about 180 degree magnetic compass direction , South.
Here is how to aim indoor and outdoor antennas , http://www.kyes.com/antenna/pointing/pointing.html.
Use a real and actual magnetic compass to aim the antenna.
____________________
The Tv Must Channel Scan for the , OTA=Over The Air , Digital Broadcast Tv stations/channels , often named the Air Channels' ~ 'Antenna Channels' in the Digital Tv Setup Menu because the Tv transmissions travel through the Air from the transmitting antenna to the receiving antenna.
Some digital tv's will Automatic channel scan for cable tv channels.
Scan for channels.
If some weaker signal strength Tv stations/channels in the Yellow/Red reception zone of the Tvfool Current Plus Pending Applications Included Digital Channel List are not received well then try reception by installing a Winegard , LNA-100 "boost" amplifier.
__________
As always , trees and tree leaves , plants and plant leaves , have a Negative effect on broadcast Tv reception and so do buildings and other obstructions including your sister own building.
The Best Practice is to install a antenna at a location that has the least amount to no amount of obstructions of any type or kind in the directions of reception.
__________
http://www.solidsignal.com.
http://www.amazon.com.
Last edited by teleview; 25-Sep-2013 at 12:18 AM. Reason: Clarify information and typos.
Old 21-Sep-2013, 6:32 PM   #3
While I find RS to be overpriced and staffed mostly by people that have little understanding of the products they sell, I'll still buy select items there on occasion.
I agree with the recommendation of the Terk HDTVi.
Old 21-Sep-2013, 7:47 PM   #4
Stereocraig
Rat Shack, is a great place to go in an emergency, when everybody else, is closed.
RS and it's employees, are the electronics equivalent of fast food chains.
