Old 31-Oct-2010, 11:55 PM   #1
freetvplease
Newbee in Mobile Alabama
Hi, My name is John. I'm wanting to setup my house with an OTA. One TV and computer will be approximately 15' from the antenna with two being 35' and the last one being 50'. My TV Fool assessment is http://www.tvfool.com/?option=com_wr...a543fcd9cbf300. My neighborhood is somewhat hilly and very tree laden. My house is a single story.
I hope this is enough info that maybe those of you that are expert at this can lead me in the right direction. I thank you all very much.
John
freetvplease is offline   Reply With Quote
Old 1-Nov-2010, 9:12 AM   #2
Tv Reception
WRBM digital channel 25 is the CW , W30BX digital channel 30 is HSN home shopping network. . Read about Real channels and Virtual channels http://forum.tvfool.com/showthread.php?t=695
Old 1-Nov-2010, 2:15 PM   #3
freetvplease
Thanks for your post, I've ran across that before from your other posts helping others. What I'm asking is, what antenna system should I get, a single or double setup? Will I probably need an amp for the farthest tv's? What model antenna should I consider?
Thanks
John
Old 1-Nov-2010, 2:28 PM   #4
Tigerbangs
TV Reception Maven
Tigerbangs's Avatar
I would suggest using a Winegard HD-7696P or an AntennaCraft HBU-44 VHF-high-band plus UHF outdoor antenna mounted on your roof, mounted as high as is practical, aimed at 85 degrees by your compass. You may want to consider using a preamplifier like a Winegard HDP-269 if you want to run multiple TV sets from the antenna. You should see all of the Mobile-Pensacola stations without any problem if you use this combination.
Here is a good antenna installation guide to get you started:
http://manuals.solidsignal.com/AntInstallGuide.pdf
Old 1-Nov-2010, 5:09 PM   #5
freetvplease
Hi Mr. Tiger, I was hoping you would address my situation and for that I thank you very much. Is the HBU-44 a single UHF/VHF unit or are you saying use the HBU-44 for the VHF and use a separate UHF mounted on the same pole?
I'm very new to all this so please be patient with me. I appreciate your help.
John
Old 1-Nov-2010, 5:34 PM   #6
Tv Reception
Both antennas are both VHF and UHF in one antenna. I would choose the winegard because it has a built in coupler for coax connection. Point it at 85 degrees
Old 1-Nov-2010, 5:58 PM   #7
freetvplease
Hi Mr. John, According to SolidSignal's website the coaxial connection is included with the HBU-44. Am I missing something? For some reason I'm kind of leaning towards the HBU-44.
Old 1-Nov-2010, 10:30 PM   #8
Tv Reception
The HBU 44 is a real fine antenna , get the HBU 44.
Old 1-Nov-2010, 11:26 PM   #9
freetvplease
OK done, ordered the HBU-44 and the HDP-269 preamp from Solid Signal. The rest of the equation I'll probably get for Lowes/HomeDepot and my local Spectronics. I'll probably have more questions as I go forth. I'm also reading that Installation PDF above. Thanks so very much Guys.
John
Old 5-Nov-2010, 12:51 AM   #10
freetvplease
Will I need to attach a ground wire to my antenna if the base of the mast will be inserted into the ground/dirt?
John
Old 5-Nov-2010, 2:35 PM   #11
John
To properly ground the mast, you still need the appropriate grounding system. Placing the bottom of the mast into the ground does not fulfill the requirements under common electrical code requirements.
Old 5-Nov-2010, 3:35 PM   #12
freetvplease
where do I purchase the clamps to attach the copper grounding wire to the Pole and my water faucet?
John
Old 6-Nov-2010, 1:11 AM   #13
Tigerbangs
TV Reception Maven
Tigerbangs's Avatar
Radio Shack has what you need
Old 6-Nov-2010, 1:56 AM   #14
freetvplease
I don't know why that just did not cross my mind. Thanks Tiger.
John
Old 6-Nov-2010, 4:48 AM   #15
Tv Reception
Lowes and HomeDepot has clamps and ground wire.
Old 6-Nov-2010, 6:26 PM   #16
freetvplease
Well, Rat Shack Blows. The only thing I was able to get at Rat Shack was the Standoffs. Better than nothing. Lowes was out of the copper wire - go figure.
I found the faucet clamp and pole clamp (same thing actually) and the Inline Coax Surge Protector at a place called Electronics Supply as no one else had a clue as to what I was talking about (I thought I didn't have a clue about this stuff - apparently I catch on fast). I could have ordered it online but I really wanted it today.
It's all coming together thanks to you guys.
John
Old 7-Nov-2010, 5:58 PM   #17
freetvplease
HOLYCRAP BATMAN!!! You guys are freakin' awesome. I'm pulling in 26 stations. I would have never guessed that was possible. The antenna without the amp pulls in 6, but add the amp and an additional twenty stations get picked up.
Right now I just have my main tv hooked up at the moment. When I catch my breath and overcome these low blood sugars I'll get to work properly wiring my other tv's.
Thank you so much guys!!!!!!!!!!!!!
John
