Old 12-Feb-2013, 5:54 PM   #21
I -->Strongly Recommend<-- do as directed and see what happens.
It is time for Action.
Old 22-Jan-2014, 1:26 PM   #22
texas1824
The setup referred to has worked pretty well. However, there are a couple of main stations (KSAT & KENS) that are somewhat weak. I'm thinking a rotator might be a better solution since almost all I watch is from the cluster of towers to the south and I only occasionally watch the others to the west and north. Plus I could put the reflector back on the CS2, which should increase its reception. Any thoughts?
texas1824 is offline   Reply With Quote
Tags
amplifier, antenna, clearstream 2, vhf
