Old 19-Nov-2012, 4:33 AM   #1
jdevries
Reception from 2 Channel groups located 120° apart
I currently have an ANT751 installed in my attic and pointing approximately in a WNW (300°) direction. I get all of the following channels (2.1, 6.1, 8.1, 10.1, 17.1, 26.1, 32.1, 42.1). Interestingly, 8.1, 10.1, 17.1, 32.1 & 42.1 are at 320°, 6.1 is at 230° and I presume that 2.1 & 26.1 are at 301°.
1) Isn't the ANT751 relatively directional and why would I be able to get channels that are spread 90° apart?
I'm going to swing my ANT751 around to approximately 260° in hopes of getting also getting 12.1, 24.1 & 28.1 which are located in a 200° direction. If this does not work, I may need two antennas.
2) Is it possible to combine the input from two ANT751 antennas with one pointing at 320° and the other at 200° without using a A/B switch box?
NOTE: I believe that your database is not showing 2.1 (CBUT; CBC English) and 26.1 (CBUFT; CBC French) however, we get do them.
Location information: http://www.tvfool.com/?option=com_wr...cc49611d7acddf
Thanks,
Jim
jdevries is offline   Reply With Quote
Old 19-Nov-2012, 6:40 AM   #2
The ANT751 is a small antenna and as such is not all that directional.
The bigger a antenna is the more directional the antenna becomes.
The ANT751 does have some directional forward direction gain , and also receives very well at the , back , back angles , and front angles. The least amount of reception is on the sides.
I recommend aim the ANT751 antenna at about 183 degree magnetic compass direction. Here is how to aim antennas , http://www.kyes.com/antenna/pointing/pointing.html.
Improved reception will happen with the antenna installed above the Roof in such a manner the reception is not blocked by the roof or the house in the directions of , north west , south west , south , east.
Here are some common roof top antenna mounts , tripod antenna mount , eave antenna mount , chimney antenna mount , J type antenna mount.
Here are some places to buy antenna mounts and ect. , http://www.saveandreplay.com , http://www.trentondistributors.com , http://www.canadapost.ca/shopper , http://www.amazon.ca , http://www.solidsignal.com , http://www.amazon.com.
As always , trees and tree leaves do a real fine job of reducing or blocking Tv reception and so do buildings and other obstructions including your own house.
It is best to install a antenna at a location that has the least amount to no amount of obstructions of any type or kind in the directions of reception including your own house.
___________________________________________
2 Tv antennas that receive different channel bands , as an example , UHF and VHF can be combined with a special coupler named a UVSJ.
However 2 antennas that are alike and aimed in different directions can not be combined , the 2 antennas will cross talk and the reception will be out of phase with 2 alike channel band antennas , the reception Will Be Bad.
The Tv channel bands are ,
UHF band channels 14 thru 51.
The data base is showing both Digital Tv stations/channels ,
CBUT-DT REAL UHF Digital channel 43 , virtual number (2.1) CBC.
CBUFT-DT REAL UHF Digital channel 26 , virtual number (26.1) SRC French Tv.
