Old 18-Sep-2012, 2:06 PM   #1
gseifried
Analyze results for Central Ontario
Looking for someone to do a results analysis and make recommendations on equipment. Here is the line to the analysis results:
http://www.tvfool.com/?option=com_wr...5ed63425d9ed6c
thanks
gseifried is offline   Reply With Quote
Old 18-Sep-2012, 3:05 PM   #2
Is this a , House , town home , condo , apartment , mobile home , motor home , or ect. ??
What floor??
What is the top floor??
What directions do the , windows , patios/balconies face??
Do any , windows /patios/balconies face a inner court yard , and what direction is that.
Do to the low signal strengths of the Digital Tv stations at 10 feet antenna height of the tvfool radar report , please make 3 more tvfool radar plot reports at 25 and 40 and 60 feet antenna heights.
Do not delete the first tvfool radar report.
Old 21-Sep-2012, 10:26 PM   #3
gseifried
Updated Analysis
Mobile home - fairly high elevation - a few pines to the south 40' away.
40' elevation results:
http://www.tvfool.com/?option=com_wr...2df993950a50cd
25' elevation results:
http://www.tvfool.com/?option=com_wr...2df9e842de4d6c
thanks
Old 21-Sep-2012, 11:34 PM   #4
The locations of the second and third tvool reports are not the same as the first tvfool report.
2.5 miles difference of the west direction.
3.2 miles difference of the east direction.
1.1 miles difference of the south direction.
1.0 miles difference of the north direction.
The correct location is important for correct reception information.
Can make the difference of , Fuzzy Analog Tv reception or Clear Digital Tv reception.
Old 27-Sep-2012, 4:10 PM   #5
gseifried
Redone with correct coordinates.
25': http://www.tvfool.com/?option=com_wr...2df97996c31b41
40': http://www.tvfool.com/?option=com_wr...2df9244c01a80a
Old 27-Sep-2012, 11:09 PM   #6
Antenna height 25 to 40 feet.
For reception of CKCO-TV Analog channel 2 , CTV ONE.
And
CIII-DT Digital channel 26 , GTN.
Install a Winegard HD7082P antenna with , no antenna amplifier , aimed at about 356 degree magnetic compass direction.
For reception of CKNX-TV/CFPL-TV Analog channel 8 , CTV TWO.
Install a Winegard YA-1713 antenna with , no antenna amplifier , aimed at about 284 degree magnetic compass direction.
The 2 antennas are not connected together on to one coax.
The 2 antennas are separate antenna systems / coax all the way to the location of the Tv.
The 2 antenna coaxes will be connected to a , Remote control A/B antenna switch , http://www.mcmelectronics.com , #32-4425. , Saveandreplay has the same remote control A/B antenna switch.
Here are some places to buy antennas and etc. , http://www.saveandreplay.com , http://www.trentondistributors.com , http://www.canadapost.ca/shopper , http://www.amazon.ca , http://www.solidsignal.com , http://www.winegarddirect.com , http://www.amazon.com.
It is best to install the antennas at a location that has the least amount to no amount of obstructions of any type or kind in the directions of reception.
The Tv Must Channel Scan for the Broadcast Tv Channels , sometimes named the 'Air Channels' or 'Antenna Channels' in the Tv setup menu because the Tv transmissions travel through the air from the transmitting antenna to the receiving antenna.
Old 4-Oct-2012, 2:35 PM   #7
gseifried
Much appreciated - thanks!
