Old 15-Sep-2012, 4:31 AM   #1
Kinetic
Antenna/Amp advice
I've been using an OTA setup since 2007, and until now I've always been <10 miles from the broadcast towers in San Antonio, TX. I moved out to Boerne, TX which puts me about 45 miles from the broadcast towers I was picking up. Here is my tvfool signal analysis:
http://www.tvfool.com/?option=com_wr...5ed67c56d51710
My previous antenna was damaged in the move, so I'm looking to pick up a new one along with an amp if necessary. I'm still quite green when it comes to the actual science of it all (living 10 miles from the towers was basically plug-n-play).
I would appreciate any help or advice. I'll be mounting the antenna on the side of my house/roof and it will probably be about 15-20ft up.
Thanks in advance!
Kinetic is offline   Reply With Quote
Old 15-Sep-2012, 6:01 AM   #2
One Tv antenna is preferd over using 2 Tv antennas for reception.
Here is a one antenna solution the can be expanded in to a 2 separate Tv antenna system by adding a second antenna if required.
Above the roof install a Winegard HD7000R antenna with a Antennas Direct CPA-19 preamp , aimed at about 160 degree magnetic compass direction.
For 1 tv connected use no splitter.
For 2 tv's connected use a , HFS-2D , 2 way splitter.
For 3 Tv's connmected use a , HFS-3D , 3 way splitter.
Here are places to buy the HFS splitters , http://www.hollandelectronics.com , http://www.solidsignal.com.
This 1 Tv antenna set up is to receive the Current Plus Pending Applications Included Digital Tv stations/channels , in the tvfool channel list , down to and including WOAI-TV NBC. In the the Green and Yellow and Red reception zones.
As always , trees and tree leaves do a real fine job of reducing or blocking Tv reception and so do buildings and other obstructions including your house.
It is best to install the HD7000R antenna at a location that has the least amount to no amount of obstruction of all types and kinds in the directions of , north east , south east , south west.
The Tv/s Must Channel Scan for the Broadcast Tv Channels , sometimes named the 'Air Channels' or ' Antenna Channels' in the Tv setup menu because the Tv transmissions travel through the air from the transmitting antenna to the receiving antenna.
Last edited by GroundUrMast; 4-Oct-2012 at 6:10 AM. Reason: Deleting off-topic content
Old 16-Sep-2012, 2:17 AM   #3
Kinetic
Thanks so much for the info!!
Old 17-Sep-2012, 5:56 AM   #4
Kinetic
After reading about the Winegard HD7000R antenna I couldn't find what the range was. Will this antenna allow to receive broadcasts from up to 50 miles away?
Last edited by GroundUrMast; 4-Oct-2012 at 6:11 AM. Reason: Deleting off-topic content
Old 4-Oct-2012, 5:16 AM   #5
Kinetic
Yes.
Signal coming in loud and clear. Really appreciate the recommendations!
Last edited by GroundUrMast; 4-Oct-2012 at 6:14 AM. Reason: Deleting off-topic content
