Old 25-Aug-2012, 2:26 AM   #1
feeth
Sharpsburg, GA antenna help please
http://www.tvfool.com/?option=com_wr...e779c8b322a12b
3-4 TVs.
ABC, CBS, FOX and NBC.
I had a CM larger antenna 5-7 years ago and it worked pretty well.
I was looking at this one:
Antennas Direct ClearStream4 HDTV Antenna
TIA for your help!
feeth is offline   Reply With Quote
Old 25-Aug-2012, 3:54 AM   #2
Tv Reception.
A Teleview Recommendation.
Some of the Tv stations are Very Weak.
Examples:
WATL , MyNetwork.
WPBA , ION TV.
To see if signal strengths improve with higher antenna height , make a second tvfool radar plot report with antenna height at 25 feet.
Old 25-Aug-2012, 4:23 AM   #3
feeth
Will repost when I get back to a PC. Thank you
Old 25-Aug-2012, 4:32 AM   #4
feeth
Examples:
WATL , MyNetwork.
WPBA , ION TV.
Link is not working.
Old 26-Aug-2012, 11:59 AM   #5
feeth
Same address with a 25' pole.
http://www.tvfool.com/?option=com_wr...e779e4ea6a628c
Old 27-Aug-2012, 8:19 AM   #6
Tv Reception.
The following is a Teleview Recommendation for Tv Reception.
The signal strengths are much improved with the antenna at 25 feet antenna height.
Many Digital Tv stations/channels will be received.
Above the roof install a Winegard HD7696P antenna aimed at about 18 degree magnetic compass direction.
For 1 Tv connection use no splitter and no amplifier.
For 2 Tv's connected use a common simple 2 way splitter and no amplifier.
For 3 or 4 Tv's connected use a Channel Master CM3414 distribution amplifier.
Here are some places to buy antennas and etc. , http://www.solidsignal.com , http://www.winegarddirect.com , http://www.amazon.com , http://www.channelmasterstore.com.
It is best mount the antenna in a manner that there is the least amount to no amount of obstructions in the direction of reception.
Old 27-Aug-2012, 8:34 AM   #7
Tv Reception.
Your location has receivable Digital Tv stations/channels in the ,
And
UHF band channels 14 thru 51.
Examples:
WXIA-DT REAL Digital VHF channel 10 , virtual number (11.1) NBC.
WPXA-DT REAL Digital UHF channel 51 , virtual number (14.1) ION TV.
The HD7696P antenna is designed to receive VHF channels 7 thru 13 and UHF channels 14 thru 51.
The CS4 is designed to receive UHF channels 14 thru 51.
