Old 25-Aug-2012, 7:45 PM   #1
liasosa
No TV signal with my TERK HDTV indoor antenna
No luck getting a picture on my new Samsung LED HDTV, not sure if the problem is the TV or the antenna, it says poor or no signal, check antenna cable. What am I doing wrong????? Need help all you experts
liasosa is offline   Reply With Quote
Old 25-Aug-2012, 8:35 PM   #2
thom
need you to post a TVFool assessment
thom is offline   Reply With Quote
Old 25-Aug-2012, 9:17 PM   #3
liasosa
No signal with TERK HDTV indoor antenna
http://www.tvfool.com/?option=com_wr...e7793a00b3da82
Old 25-Aug-2012, 9:47 PM   #4
thom
Were you getting good signals on a prior TV?
Also, the TV is not on its Cable setting, but Antenna (or Air or Broadcast), right?
Old 25-Aug-2012, 9:49 PM   #5
liasosa
I do not have cable or satelite, but I used to get a few local channels on my old TV that had a convertor box and a Tivax indoor antenna. Now I got a new TV and a new antenna and for some reason I am not getting a single channel, trying to figure out what the problem is. I live in NYC and the towers about 12 miles. Would appreciate any guidance... thanks
Old 25-Aug-2012, 9:52 PM   #6
liasosa
Thanks Thom, how do I check to see if the TV is on antenna and not the cable setting?
Old 25-Aug-2012, 10:10 PM   #7
Tv Reception.
A Teleview Recommendation for Tv Reception.
The Main groups of Digital Tv stations/channels are to the south west , aim the HDTVa antenna at about 220 degree magnetic compass direction.
Here is how to aim indoor antennas , http://www.kyes.com/antenna/pointing/pointing.html.
Put the antenna in a window that is to the south west type direction.
The Tv Must Channel Scan for the Digital Broadcast Tv Channels , sometimes named the 'Air Channels' or 'Antenna Channels' in the Tv setup menu because the Tv transmissions travel through the air from the transmitting antenna to the receiving antenna.
____________________________________________
Your location has receivable Digital Tv stations/channels in ALL 3 Tv bands.
UHF band channel 14 thru 51.
Examples:
WKOB-LD REAL VHF channel 02 , virtual number (42.1) http://www.hottvchannel.com.
WABC-TV REAL VHF channel 07 , virtual number (7.1) ABC.
WWOR-TV REAL UHF channel 38 , virtual number (9.1) My Network.
That being the case , All Tv bands , Install a large ALL Band Tv Antenna.
If this is a , house , town home , condo , mobile home , or etc.
Install a Winegard HD7082P antenna with - no preamplifier - Above the roof aimed at about 220 degree magnetic compass direction.
Here is how to aim outdoor antennas , http://www.kyes.com/antenna/pointing/pointing.html.
For 1 Tv connected use no splitter , no amplifier.
For 2 Tv's connected use a common simple 2 way splitter , no amplifier.
For 3 or 4 Tv's connected use a Channel Master CM3414 distribution amplifier.
Old 25-Aug-2012, 10:16 PM   #8
Can you give us the model number of the TV? Your user manual should provide the instructions on how to set the tuner to 'antenna' or 'air'.
Old 25-Aug-2012, 10:20 PM   #9
Tv Reception.
Here are some Strong And Sturdy antenna mounts , http://ronard.com/909911.html , http://www.ronard.com/34424560.html , http://www.ronard.com/ychim.html , http://www.ronard.com.
Here are places to buy antennas and etc. , http://www.solidsignal.com , http://www.amazon.com , http://www.winegarddirect.com , http://www.channelmasterstore..
Old 25-Aug-2012, 10:30 PM   #10
Tv Reception.
As always , trees and tree leaves do a real fine job of reducing and blocking Tv reception and so buildings and other obstructions.
It is best to install the antenna at location that has the least amount to no amount of obstructions in the direction of reception (south west).
The Tv's Must Channel Scan for the Digital Broadcast Tv Channels , sometimes named the 'Air Channels' or "Antenna Channels' in the Tv setup menu because the Tv transmissions travel through the air from the transmitting antenna to the receiving antenna.
Old 25-Aug-2012, 10:43 PM   #11
liasosa
No signal with TERK HDTV indoor Antenna
My TV is Samsung LED TV Model UN40C6400RF
Old 25-Aug-2012, 11:09 PM   #12
Hello liasosa:
Downloads & FAQs here:
http://www.samsung.com/us/support/ow...ct/UN40C6400RF
Manual here:
http://downloadcenter.samsung.com/content/UM/201009/20100906134240296/[UC6500-ZA]BN68-02711D-03Eng.pdf
pp 8, 9, & 14
The attachment shows the difficult terrain path for the WABC signal.
Old 26-Aug-2012, 12:03 AM   #13
liasosa
Thanks, Rabbit 73. I'm not very tech savvy.......
Old 26-Aug-2012, 1:05 AM   #14
Your welcome.
No problem; we all start as beginners.
Please let us know how it works out at Mum's home.
Old 26-Aug-2012, 8:40 PM   #15
liasosa
So the problem was the TV set to the cable setting, changing it to Air channels and then auto scanning for channels got me about 12 channels, of which just one, CBS has a real good signal. I guess now its a matter of just positioning the antenna to get better reception, but for now I'll leave it alone so mum can watch her fav 60 mins show tonight.
Would having an out door antenna be a better choice? It seems such a waste having a great TV (the pic quality is just awsome) with such limited coverage.
Thanks so much everybody, what a great site......
Old 27-Aug-2012, 12:12 AM   #16
Tv Reception.
The following is a Teleview Tv Reception Recommendation.
For Reception of Many more Digital Tv stations/channels , do as Teleview has recommended.
Old 27-Aug-2012, 2:54 AM   #17
thom
Glad to hear you got it going.
Yes, outdoor is always going to be better. Getting some altitude (you can experiment on TV fool with antenna elevation) will generally improve your situation provided you don't have obstacles like buildings or trees in your near field.
