Old 8-Aug-2012, 10:08 PM   #1
Cheeva316
Antenna help best suited to my area tvfool report
Here is the report , my father is looking for an outdoor antenna and he has 1 lcd tv and just bought a brand new led tv so he wants to get rid of his walmart indoor antenna that only gets maybe 6-7 channels... he would be happy if he could get at least 20-30+ channels... he wants something that is good qaulity and from my idea im thinking the least amount of plastic hardware the better??
I did find the clear steam 5 but again im not too knowledgeable to this type pf technology... please help..thanks
http://www.tvfool.com/?option=com_wr...9900a303e3c48a
Cheeva316 is offline   Reply With Quote
Old 9-Aug-2012, 3:17 AM   #2
Cheeva316
please someone help as I am trying to order a antenna tomorrow
Old 9-Aug-2012, 4:37 AM   #3
Tv Reception.
A simple reception situation.
Many , many , many , many , Digital Tv stations/channels will be received.
Above the roof install and aim a Winegard HD7696P antenna with No amplifier at about 180 degree magnetic compass direction.
Here are places to buy antennas and etc. , http://www.solidsignal.com , http://www.winegarddirect.com , http://www.amazon.com.
Old 10-Aug-2012, 10:44 PM   #4
Cheeva316
thank you very much I will order that Antenna tonight.
Old 10-Aug-2012, 11:08 PM   #5
Cheeva316
Sorry I actually found this one by mistake actually so would this one suit better and possibly get more channels or better over all?? >> Winegard HD7697P
Thanks in advance
Old 11-Aug-2012, 1:17 AM   #6
thom
sure, it'll work, but it's big
here's some useful info
http://www.winegard.com/kbase/upload/HD7697P.pdf
http://www.winegard.com/kbase/upload/HD7696P.pdf
http://www.winegard.com/kbase/upload/HD7694P.pdf
the 7P is almost 11 feet long.
thom is offline   Reply With Quote
Old 11-Aug-2012, 2:34 AM   #7
The wider beam-width of the 7696 in the high-VHF band has been useful in a few situations like yours. Pointing at 180° in an effort to receive real CH-48 while still seeing the main group of signals at 150° calls for the wider beam-width of the 7696 rather than the 7697 or 7698.
It's nice to see that Winegard has kept all of the 769X series antennas in production.
Old 11-Aug-2012, 3:12 AM   #8
thom
and now for something completely different...
Just to throw another log on the fire, you might consider the DB4e from Antennas Direct
http://www.antennasdirect.com/cmss_f...y/DB4E-TDS.pdf
Substantial gain in a small package, and it has a fat beam (see the link). The one wrinkle is the single VHF station, but the DB4e will act like a VHF antenna off the boresight (not guaranteed to work here, but it's working for me). Even if it doesn't, you can add a dipole add-on for $20 that should suffice.
You can get the DB4e delivered from SolidSignal for $50.
Old 11-Aug-2012, 8:13 AM   #9
Tv Reception.
Your location has receivable Digital Tv stations/channels in the VHF high band channels 7 thru 13 and UHF band channels 14 thru 51.
_________________
The HD7696P antenna designed to receive VHF high band.
WTSP , VHF channel 10 CBS.
WFLA-DT , VHF channel 7 NBC.
WTVT-DT , VHF channel 12 FOX.
WEDU-DT , VHF channel 13 PBS.
The rest of the receivable digital Tv channels are UHF digital channels.
The HD7696P antenna is also designed to receive the UHF band.
_____________________________
The DB4e is designed to receive the UHF band channels 14 thru 51.
The DB4e Is Not Designed to receive the VHF high band channels.
Old 11-Aug-2012, 4:13 PM   #10
thom
theory and practice
The one on my roof is consistently receiving a 2Edge VHF 8 and 10 from 20 miles out, 90 degrees off axis. ADTech also indicated they saw similar behavior in field tests, just not something they are going to advertise. Yes, everyone's mileage may vary, but as I noted, failing that, a $20 add on (all necessary cables and joiner included) will resolve it. Even with that, you still come out cheaper than the Winegard. All of Cheeva's reasonable VHF channels are LOS and have enough power to be pulled with the dipole if not the base DB4e.
Even after accounting for the dBd/dBi normalization between the 6P and DB4e, the UHF gain between the two is comparable. The DB4e, however, has a much wider beam, which is well-suited to his Southern spread.
Something you're not considering is the practical aspect of getting it and keeping it installed. You're sending Cheeva up a ladder and onto the roof with a 10 pound, 10 foot long package with the Winegard versus a 4 pound, 3 foot long package with the DB4e (not to mention that when extended the Winegard is like a giant spiny crustacean). Maybe you can handle the Winegard on the roof with your eyes closed, but it's a pretty good guess that people posting for help in this forum are not going to be all that adept wielding that kind of object on the ladder or roof.
Likewise, once it's on the mast, you've got more than twice the weight on the end of the pole, and much of that weight is away from the center of the mast instead of directly on the mast like a bay antenna. Again, an experienced installer can compensate for the mass and wind loading, but that's not who's asking questions here.
I've done both the Winegard and DB4e. For my money, the DB4e is cheaper, just as effective, and much easier to install. It also wins aesthetically; most people don't even notice it on the roof. As an added bonus, birds won't perch on the DB4e and make a mess of my roof, either.
Old 11-Aug-2012, 4:50 PM   #11
Tv Reception.
Those antenna haters are something when their true feelings come out.
The HD7696P antenna is correct.
Old 11-Aug-2012, 7:23 PM   #12
If this was my circumstance, I'd opt for the HD7696P also.
I have confidence in the DB4e as a UHF antenna, but would expect to need a five or even ten element Yagi (Y5713, Y10713 or YA1713) high-VHF antenna to make the four real VHF signals reliable.
Old 11-Aug-2012, 10:45 PM   #13
Tv Reception.
The HD7696P antenna is a antenna that receives all the receivable channels. , UHF and VHF.
No requirement to install a DB4e UHF antenna and then a second antenna to receive VHF channels.
Old 13-Aug-2012, 6:10 AM   #14
thom
Those antenna haters are something when their true feelings come out..
haha, perhaps you mistake passion for hate.
I love antennas. The fact that you can pull a signal out of thin air with an aluminum stick is one of the more fascinating aspects of electronics.
However, as an engineer, I'm looking for a solution. I suppose if there is something I do hate, it's an unnecessarily expensive, heavy, large, and complicated solution. If you can meet your db gain requirements with less, why invite the complications of more (and yes, there are always complications).
I understand the reticence over a VHF add-on dipole, but consider this.
http://www.tvfool.com/?option=com_wr...990027c93c8ecd
and the associated image below.
That's a 2Edge, 97 mile, 3.2NM signal which is entirely watchable with the dipole The original poster's toughest VHF station is LOS, 42 mile, 27.7NM. I think there's ample room for friendly disagreement on this one.
