Old 3-Aug-2012, 11:12 PM   #21
Tv Reception.
14.4 NM(dB) , http://www.tvfool.com/?option=com_wr...9900a162895b54
Old 4-Aug-2012, 2:22 AM   #22
The difference between the 'Current' and 'Pending' values don't explain the great difference between our results... If I'm using flawed math, I would like to be corrected.
http://forum.tvfool.com/showthread.p...6744#post26744
Old 4-Aug-2012, 5:25 AM   #23
Tv Reception.
The difference between 11.6 and 14.4 is plus +2.8 NM(dB).
Normaly +1 to +2 and even +3 NM (dB) is not important for reception.
However there are some reception situations where +1 , +2 , and even +2.8 NM (dB) is better then nothing and is better then -1 , -2 , -2.8 NM (dB).
Old 4-Aug-2012, 6:26 AM   #24
Tv Reception.
Running the numbers , looks impressive , learned how to do it years ago.
Getting in to it in depth here at tvfool , learned my lesson here , won't do it again.
As I at least tried to explain in the past there is more to obtaining reliable transmission of Digital VHF low band channels 2 thru 6 through out a coverage area and how that positively effects reception. Beyond what the numbers say.
