Old 20-Feb-2012, 5:05 PM   #1
iceman
set up antenna
http://www.tvfool.com/?option=com_wr...xxxxxxxxxxxxxx .WONDERING IF ANY ONE LIVES IN THE AREA OF WILSON AND HILLCROFT .HOW MANY CHANNELS ARE THEY GETTING .THANKS
for a house
iceman is offline   Reply With Quote
Old 20-Feb-2012, 9:05 PM   #2
Tv antennas and Tv reception
Do what the other question askers do and Do This-> http://forum.tvfool.com/showthread.php?t=4. Is this a , house , condo , apt. , mobile home , motor home or etc.?? Make the tvfool radar report with the exact address and make the antenna height 25 feet.
Old 21-Feb-2012, 2:24 AM   #3
MisterMe
Originally Posted by iceman View Post
You link points to the TV Fool Radar plot location entry page and not to your TV Fool Radar plot.
Old 23-Feb-2012, 1:25 AM   #4
iceman
antenna set up
hi every one
i was wondering if anyone lives near wilson and hilcroft how many channels are you getting im in a house .i want to set up a antenna
i was checking out the digiwave 2086 at durham radio
thanks
Old 23-Feb-2012, 2:08 AM   #5
You are getting close to doing it correctly. What is needed is a Live and Active Radar Plot not a picture of the radar plot. Check out what the other question askers have done and post a radar plot like they have done. And as far as digiwave goes , no one here will recommend any of the cheap china antennas that are sub standard in every way. . Read what http://www.saveandreplay.com has to say about clone antennas.
Old 23-Feb-2012, 11:58 PM   #6
oldjake135
Smile oshawa hillcrest&wilson
http://www.tvfool.com/?option=com_wr...0b863e7dafec76 and it is a house 10 ft pipe above the roof all to gather that would be about 40 ft above the ground . not sure what the best antenna would give me the best reception, any help on antenna, as well of how many channels i would get, thanks for any help
oldjake135 is offline   Reply With Quote
Old 24-Feb-2012, 12:06 AM   #7
oldjake135
Thumbs up iceman
check it out now that you did it right. dont worry we all have to learn.
Old 24-Feb-2012, 12:39 AM   #8
Install a Channel Master CM3679 antenna , http://www.saveandreplay.com. Aim the CM3679 antenna at about 195 degree magnetic compass , Here is how to aim antennas , http://www.kyes.com/antenna/pointing/pointing.html . Mount the CM3679 antenna above the roof. Also install a Antennas Direct CPA-19 preamp , saveandreplay now stocks the Antennas Direct , http://antennasdirect.com , CPA-19 preamp. Also use new RG-6 coax on the outside , standard RG-6 coax will be fine. No need to use quad shield coax RG-6 coax. Yes you can use quad shield if you decide to. For normal low interference reception situations , quad shield is not needed but yes you can use it if you like.
Old 25-Feb-2012, 2:08 AM   #9
iceman
Thank you very much for your help Electron
once the weather gets better im going to do it.
have a great weekend
