Old 23-May-2010, 5:57 PM   #1
IslandGuy
Whidbey Island Help
Like others we are disconnecting our Comcast cable...all that money and nothing is on...
I have a nice 42" HD Panasonic TV and Denon component system. First off I will need a roof-top antenna. Here is my location:
http://www.tvfool.com/?option=com_wr...9fbe1ee01e4488
I am only interested in the channels to the south...
Next will be to find a HDTV Tuner for my system.
Thanks for any help!
Jim
IslandGuy is offline   Reply With Quote
Old 23-May-2010, 6:01 PM   #2
No static at all
No static at all's Avatar
Unfortunately, your link does not work. Can you try it again?
Old 23-May-2010, 7:46 PM   #3
IslandGuy
whoops...udpdated the link!
Thanks!
Old 23-May-2010, 10:43 PM   #4
No static at all
The Winegard HD7696P looks to be a good choice. If I'm reading the specs right, it shows a wide beam width for VHF, so you should be able to aim the antenna around 130 degrees & receive all the stations to the south. I would try it without a preamp first if you are only powering 1 TV & using less than 100 feet of RG-6 coax.
Hopefully others will chime in if I am misreading the beam width specs or with other suggestions
Old 23-May-2010, 11:48 PM   #5
IslandGuy
Thanks for the information. We may end up powering another TV as well but the total length of coax will be less than 100 feet.
Jim
Old 24-May-2010, 2:55 AM   #6
Tigerbangs
TV Reception Maven
Tigerbangs's Avatar
The HD-7696P is a wise choice, but I would skew the aim slightly so the antenna sees KCPQ clearly: try about 150 degrees instead of 130 for your aiming. If you plan to run two or more TV sets, I suggest using a high-input preamplifier like a Winegard HDP-269, which will overcome the line and splittine losses associated with tunning multiple TV sets.
Old 24-May-2010, 2:59 AM   #7
IslandGuy
Thanks for your help! Now what HD TV tuner do you recommend?
Jim
Old 24-May-2010, 11:55 AM   #8
Tigerbangs
TV Reception Maven
Tigerbangs's Avatar
If your Panasonic is less than 3 years old, chances are that it already has an HDTV digital tuner installed: if it is older, then you'll need an outboard tuner. If you provide the model number, I can tell you whether it has an HDTV tuner or not.
Old 25-May-2010, 8:52 PM   #9
IslandGuy
TH 42 PHD8
Pretty sure no tuner...
Thanks!
Old 26-May-2010, 12:57 AM   #10
Tigerbangs
TV Reception Maven
Tigerbangs's Avatar
ftp://ftp.panasonic.com/pub/Panasoni...H-42PHD8UK.pdf
No, your TV is a commercial-type monitor, so it has no tuner in it. Bummer!
The set has component and PC-connectors, but does not have HDMI inputs. You will need a tuner that provides component (red, blue and green) connections.
eBay is full of good HDTV digital tuners, however you need a true HDTV TUNER, NOT a converter box. Digital ATSC HDTV tuners will output a true HDTV signal: digital converters will NOT.
The Samsung DTB-260f is one of the best HDTV tuners that was made; they are no longer made, but can be found for about $150.00 on ebay:
http://cgi.ebay.com/Samsung-DTB-H260...item4cee72758f
http://cgi.ebay.com/Samsung-DTB-H260...item414fc4dd50
Old 26-May-2010, 1:53 AM   #11
IslandGuy
Best,
Jim
