Old 18-Sep-2011, 3:34 PM   #1
Frank_N
Looking for the correct antenna
Hi,
I have completed a report about what channels I may be able to get and depending on what I can get OTA, I may get rid of my cable. I would prefer a fixed mount antenna if possible. In my area there are some hills and many trees that may affect reception.
Could someone help me by recommending an antenna.
Here is the report.
http://www.tvfool.com/?option=com_wr...14f30569ed93b2
Thanks for your help.
Frank
Frank_N is offline   Reply With Quote
Old 18-Sep-2011, 4:20 PM   #2
How many tv's are/will be connected??
Old 18-Sep-2011, 9:32 PM   #3
Frank_N
Hi John,
Initially, only one but a second one in the future.
Old 19-Sep-2011, 4:47 AM   #4
August 31 , 2011 was the 'main' analog to digital transition date for Canada. Tvfool is currently being up dated to show the new digital and analog channels in Canada. Canada will have a mix of digital and analog channels for a long time in to the future. And analog channels will be changing to digital channels as time goes along. Some tv stations will move to new geographic locations , and that is the way it will be. http://www.tvtechnology.com/article/117022 , http://www.tvtechnology.com/article/105462. For your location I recommend a Channel Master CM3679 antenna mounted on a Channel Master CM9521A rotor , the current and pending applications list shows analog and digital channels all around the compass. The rotor will allow you to turn the antenna to find and watch tv stations. I recommend print out the current and pending applications list so you will more easyly know when tvfool is updated for your location. Here is a place to buy antennas and etc. , http://www.saveandreplay.com , http://www.trentondistributors.com.
Old 19-Sep-2011, 4:57 AM   #5
Here is more inflammation about the Canada digital and analog transition. http://www.user.dccnet.com/jonleblan...da_TV_stations , http://www.digitalhome.ca , http://www.friends.ca , http://www.crtc.gc.ca/eng/home-accueil.htm , http://www.canada.com/entertainment/...ion/index.html. So that you will know that Canada and the USA are not the only countries that are going digital , http://www.en.wikipedia.org/wiki/Dig...ion_transition
Old 19-Sep-2011, 12:48 PM   #6
Dave Loudin
Before you buy anything, check in with the thread for your area within the reception results sub-forum of the OTA forum at digitalhome.ca.
Old 19-Sep-2011, 6:29 PM   #7
Frank_N
Hi John,
Thanks for the information. The stations in Canada have switched over to digital. The CM3679 is quite big. Would I have any luck with the Antennacraft HBU22?
Old 19-Sep-2011, 6:30 PM   #8
Frank_N
Hi Dave, I will check that out.
Thanks, Frank
Old 22-Sep-2011, 1:23 AM   #9
Frank_N
Only one TV
Hi John, if I went to a only one TV, could I use a smaller antenna. The one that you mentioned is really big.
Thanks,
Frank
Old 22-Sep-2011, 1:55 AM   #10
It is not a situation of the number of tv's that is a factor of antenna selection at your location. It is receiving the tv stations that can be received. Use what ever antenna you choose to use. Any antenna will get you some stations. My suggestion/recommendation is to cover all the bases. However like I say , please use any antenna you choose. And please seek other advice. Here is a Canada web site that has a forum for broadcast digital television for the area of Canada that you live , you will find advice givers there , http://www.digitalhome.ca
