Old 4-Aug-2012, 12:42 PM   #1
trent
6 ft high antenna portable
need help picking a antenna. Suggestions anyone?
zip code 43080, antenna will be mounted on 6ft pole and made portable.
trent is offline   Reply With Quote
Old 4-Aug-2012, 12:55 PM   #2
signals unlimited
Did you not post a signal report because you are portable and moving around in the zip code or is there a most used location? If so a TVF signal report would be helpfull.
Old 4-Aug-2012, 1:56 PM   #3
trent
I did not understand how. The 43080 zip code is primary area the antenna will be located
Old 4-Aug-2012, 3:12 PM   #4
signals unlimited
Portable implied that you may be using the antenna at various locations. If that were the case then the zip code report could be relevent.
I will look at the report that you posted and reply with a recommendation.
Old 4-Aug-2012, 6:13 PM   #5
trent
reply
o.k. thanks its appreciated
Old 4-Aug-2012, 7:26 PM   #6
signals unlimited
Use the Winegard MS2000 omni-directional antenna provided that you have power available where you plan to use it, as it requires a power source to run the built in pre-amplifier.
If you need portability and are using a battery operated set where power may not be available, use the 'Sidewinder' un amplified omni-directional antenna from www.tripleplayantenna.com
Old 6-Aug-2012, 12:58 AM   #7
Tv Reception.
Take a look at the HD VIEW 360 at , http://www.antennacraft.net.
Operates on 110 volt or 12 volt.
But then if you just want a antenna to put on a pole , then ANT751.
