Old 10-Nov-2010, 2:31 PM   #1
David
Help with TV Fool Report
Hello!
I am looking for some help interpreting my TV Fool report:
http://www.tvfool.com/?option=com_wr...81a345eb698198
I would like to discontinue my cable TV service and try an antenna/Netflix combo. My household won't be happy with this switch unless I can receive all the networks (CBS, ABC, NBC, PBS, and FOX) with the antenna. Of the available networks, I would prefer to receive WWNY (CBS) and WPBS. I don't know if it's worth trying to receive WWNY, since it's the only VHF channel I'd be likely to receive.
I can mount an antenna on the west side of my house, at the peak, 25-30' above ground surface. To the east/south-east, approximately 30' away, is a large maple tree. There are no obstructions in any other direction.
So, I'm looking for help with the report to determine if I'm likely to receive all the networks. Am I right that the channels in green/yellow will be fairly easy to receive?
Also, can anyone offer me advice or recommendations on equipment to try? Of course, I'd like to keep everything as simple as possible. I am fairly handy, so I will install this myself.
Thanks very much in advance...I really appreciate any advice!
Dave
David is offline   Reply With Quote
Old 10-Nov-2010, 3:02 PM   #2
Yes, all the networks can be received from Syracuse. It's easy to add WWNY using a second antenna without the complication of a rotor. WPBS will need a rotor or a third antenna and a filter/joiner.
I'd consider a 4 bay UHF for Syracuse and a Y10-7-13 for WWNY. Add them together with a UVSJ. If you split to multiple TV sets, use an AP-2870 preamp instead of the UVSJ.
Old 11-Nov-2010, 5:32 AM   #3
Tv Reception
I recommend a XG91 UHF antenna pointed south and a HD7695P pointed north east. With a remote control A/B switch at each tv location. And you can experiment with a HD7084P pointed at the Canada stations. http://www.digitalhome.ca , http://www.crtc.gc.ca/eng/home-accueil.htm , http://www.tvtechnology.com/article/105462 , http://www.digitalhome.ca/forum/showthread.php?t=30998
Old 11-Nov-2010, 10:54 AM   #4
David
Thanks very much for the help, it is really appreciated! I will definitely take a look at the suggested equipment...I need to get on this before snow comes!
Thanks again,
Dave
Old 11-Nov-2010, 9:09 PM   #5
Tigerbangs
TV Reception Maven
Tigerbangs's Avatar
What Tower Guy said: right on the money!
