Old 2-Mar-2017, 7:46 AM   #1
rekop123
Antenna expertise requested
I have previously had service with Direct tv and Charter cable.I'm trying to set up an antenna and am only concerned with receiving the major stations, ABC, CBS,NBC, Fox, etc. I live in a trailer park in Porterville,Ca. which is in the southern part of the San Joaquin Valley between Bakersfield and Fresno. I'm pretty sure I'm going to need a rooftop installation, I'm just not sure which antenna would be my best option, how high it needs to be mounted and which direction it should be pointed to along with any splitters, amplifiers or anything else that would be needed. Any help would be much appreciated. Thanks
http://www.tvfool.com/?option=com_wr...e6a40fc59cad6b
rekop123 is offline   Reply With Quote
Old 2-Mar-2017, 3:57 PM   #2
rickbb
That's a tough location, you have a few independents close by, but the majors are behind several hills which puts you down in a RF shadow.
Old 2-Mar-2017, 8:07 PM   #3
Welcome, rekop123
rickbb is correct, it's a tough location. I doubt that you will be able to get all the networks you want, but you might get some of them.
The problem is that they are weak and in different directions.
You can have several antennas aimed in different directions, or one antenna with a rotator.
Your best chances, in descending order, are for
KMPH Fox
http://www.rabbitears.info/market.ph...&callsign=kmph
KVPT PBS
http://www.rabbitears.info/market.ph...&callsign=kvpt
KERO ABC
http://www.rabbitears.info/market.ph...&callsign=kero
KBAK CBS
http://www.rabbitears.info/market.ph...&callsign=kbak
KSEE NBC will be the most difficult. At 74.5 miles away, the curvature of the earth will interfere with the signal
http://www.rabbitears.info/market.ph...&callsign=ksee
http://www.tvfool.com/?option=com_wr...ALLTV%26n%3d15
The last hill on the path near Zante causes the most harm to the KSEE signal.
Old 2-Mar-2017, 8:49 PM   #4
rekop123
Thank you both for your replies. What equipment would you suggest I purchase that you believe would give me the best chance of receiving the stations you mentioned? Also, in your opinion, do you think the cost would justify taking a chance of maybe being able to get reception? I realize there are no sure things but your opinion would be appreciated. Thanks
Old 2-Mar-2017, 11:21 PM   #5
Here is a coverage map for KSEE:
and here is a terrain profile for KSEE using different software:
Old 3-Mar-2017, 12:04 AM   #6
Glad to hear you are willing to experiment.
If cost is not a factor, I suggest a Winegard HD7698P antenna, an Antennas Direct Juice preamp, a Yaesu G450A heavy duty rotator, and an Antennas Direct FM filter if needed. If your TV is not able to add a channel after scan, you will need to rescan after each change of direction. If more than one TV is being used, someone has to decide which direction for the antenna.
If cost is a factor, I suggest you try one inexpensive fixed antenna to see what you can get. First try a Solid Signal HDB91X UHF antenna aimed at 356 degrees magnetic for KMPH Fox. If the signal is too weak, add an RCA TVPRAMP1R preamp.
Next aim the antenna at 138 degrees magnetic to see if you can receive KBAK CBS.
Then, aim it at 329 degrees magnetic to see if you are able to receive KSEE NBC. That antenna has a tilt feature; sometimes it helps to tilt the front end up (maybe 10 to 15 degrees) to catch signals coming down from a peak.
Then add an MCM 30-2476 VHF antenna aimed at 138 degrees magnetic for KERO ABC. The RCA preamp has separate VHF and UHF inputs for the two antennas; move the switch to separate. If the switch becomes erratic, set it back to combined and use a UVSJ before the preamp to combine the two antennas.
