Old 26-Mar-2011, 12:50 AM   #1
rextoba
Smile The Playoffs at the lake
I trying to figure out whether satellite or OTA. There is Bell and Shaw satellite reception already but if I can get CBC and maybe a couple other channels OTA that would be great. There are trees in the surrounding area that could possibly be an issue. Any help would be great.
Thanks
http://www.tvfool.com/?option=com_wr...8d17411b1d8e09
rextoba is offline   Reply With Quote
Old 26-Mar-2011, 2:33 AM   #2
You have six stations just over a mile north of you. They are very low power though. An outdoor UHF panel antenna such as the Antennas Direct DB-8, Winegard HD8800, Channel Master CM-4228 or Antennacraft U8000 will give you the best shot at a nice snow free signal.
A smaller antenna will still work, though the quality of the signal will not be quite as good.
The rest of the stations on your report would require a large all channel antenna and rotator. The Antennacraft HD1850 or Winegard HD-8200U come to mind.
Old 26-Mar-2011, 2:45 AM   #3
Tv antennas and Tv reception
The six channels at 3 degrees magnetic compass are analog tv channels. I suggest a roof top Tv antenna. I suggest a Antennasdirect 91XG UHF TV antenna. The 91XG will supply signal to 1 or 2 Tv's.
