Old 21-Mar-2014, 1:45 PM   #1
nickster
Ctv 11.1
I live in Newcastle Ont. east of Oshawa, my set up is a Channel Master 4221 on a mast on side of my second level house. With good weather I can scan 28 channels, but have a hard time with CTV 11.1. I know that this is a VHF signal, I also use a RCA line amp. When I do get signal it is good at 85%.I have looked at map and I am in the green zone where I live.
nickster is offline   Reply With Quote
Old 21-Mar-2014, 3:46 PM   #2
Please post a link to your TV Fool reception report. Thanks
Old 21-Mar-2014, 4:07 PM   #3
The only virtual channel 11.1 in your area is CHCH, a UHF station (ch 15) from Hamilton, almost 80 miles away.
There are no VHF-11 signals in range of your area.
Old 21-Mar-2014, 4:15 PM   #4
Please make and post a tvfool report.
Go to the tvfool home page and click on >>Start MAPS<< .
Enter the Exact address.
Make the antenna height in the report , 25 feet above ground.
25 feet above ground is a Reference antenna height that provides a good initial evaluation of what can be received.
Post the tvfool report so your reception situation can be correctly evaluated.
Old 22-Mar-2014, 2:50 PM   #5
nickster
Sorry, I should have said CTV 9.1. I have raised the antenna to 22 feet and I am getting 2 green bars at 91% with good weather. Does CTV power down their transmission signal during the day?
Thank you
Nick
Old 22-Mar-2014, 11:19 PM   #6
No. The only time that stations reduce their power is when they must. Usually that would be due to either a failure in their system or if maintenance crews have to to be on or near the tower and power has to be reduced for their safety.
Old 8-Apr-2014, 12:50 AM   #7
nickster
channel loss when it rains
When it rains I lose 10 channels, from 32 to 22. I have a channel master 4221 up to 22 feet and a 16db indoor amp. When I have good weather most signals are 3 and 4 bars which gives me a good picture.I live in Newcastle Ontario Canada.
Old 8-Apr-2014, 1:02 AM   #8
As requested.
Please make and post your Tvfool report.
Last edited by teleview; 8-Apr-2014 at 6:58 AM. Reason: Clarify information and typos.
Old 8-Apr-2014, 2:46 AM   #9
Trees, distance, etc......
Old 8-Apr-2014, 4:32 AM   #10
Please review http://forum.tvfool.com/showthread.php?t=4
