Old 20-Sep-2012, 9:43 PM   #1
lilburncobb
Need Help with what Antenna in Lilburn, GA (suburb of Atlanta)
I am looking to ditch my cable and just would like the local channels in hd (ABC, NBC, CBS, FOX, CW, etc.) and have no idea what antenna to purchase. My results page is
http://www.tvfool.com/?option=com_wr...2df93b2d6626e7
do I need an indoor antenna, an outdoor antenna? Any suggestions on reasonable good working models for whatever I need would be really great.
Thanks in advance for your guidance.
Susanna
lilburncobb is offline   Reply With Quote
Old 21-Sep-2012, 12:20 AM   #2
An indoor antenna may work if your home construction does not block or reflect signals. An outdoor antenna mounted high enough to clear nearby trees and buildings will do very well.
I would use an RCA ANT-751.
How many sets will be connected?
Old 21-Sep-2012, 11:59 PM   #3
The following is a Teleview recommendation for digital broadcast tv reception.
http://www.solidsignal.com has a ANT751 antenna with a J type antenna mount , low dollars.
Aim the ANT751 at about 270 degree magnetic compass direction , west.
Tv Tv transmissions are strong.
A antenna amplifier is not required.
For 3 Tv's connected use a common simple 3 way splitter.
It is best to install the antenna at a location that has the least amount to no amount of obstructions in the directions of reception.
At your location that is , north west , west , south west.
The Tv's Must Channel Scan for the Digital Broadcast Tv Channels , somrtimes named the 'Air Channels' or 'Antenna Channels' in the Tv setup menu because the Tv transmissions travel through the air from the transmitting antenna to the receiving antenna.
Tags
antenna choice, antenna help, antenna recommendation, atlanta, local hd
