Old 25-Aug-2012, 2:20 AM   #1
Double Spaced
Antenna selection help
Hello everyone,
I'm finally "cutting the cable" and trying to sift through all the antenna options. I was originally thinking about getting the Leaf antenna, but I'm learning that it just won't be enough. I'm in Snohomish, WA and did a signal analysis and it can be found here
Solidsignal.com recommended the Winegard HD 7696P. I've heard good things about the RCA ANT751R too. I'm not worried about getting every single channel, mostly just the ABC, CBS, NBC and PBS networks. The only VHF channels I'd really like to receive are KSTW and KCPQ on channels 11 and 13. Everything else is a bonus.
I can mount the antenna outside on the roof if necessary, but I'd like to try the attic for the sake of cosmetics--although functionality will be the ultimate deciding factor.
Thanks in advance for any help you can provide,
Mike
Double Spaced is offline   Reply With Quote
Old 25-Aug-2012, 3:41 AM   #2
Tv Reception.
A Teleview Recommendation for reception.
All Digital Tv stations/channels requested and many more will be received.
Install a Winegard HD7696P antenna above the roof aimed at about 180 degree magnetic compass direction.
For 1 Tv connected use no splitter or amplifier.
For 2 Tv's connected use a common simple 2 way splitter , no amplifier.
For 3 Tv's connected use a common simple 3 way splitter , no amplifier.
Here are some antenna mounts , http://www.ronard.com/9099011.html , http://www.ronard.com/34424560.html , http://www.ronard.com/ychim.html , http://www.ronard.com.
Here are some places to buy antennas and etc. , http://www.solidsignal.com , http://www.winegarddirect.com , http://www.amazon.com.
As always trees and tree leaves do real fine job of reducing or blocking Tv reception and so do buildings and other obstructions in the direction of reception.
Mount the HD7696P antenna where there is the least amount or no amount of obstructions.
