Old 2-Aug-2012, 2:52 PM   #1
mapreston
Surrounded by many tall trees
We are having trouble receiving any channels at this time. We have tried numerous options and are getting tired climbing on the roof to experiment. We live in the woods and are surrounded by many tall trees. We currently have a roof mounted antenna, I believe it would be considered a medium size multi-directional antenna. We also have a booster/amplifier near the base of the antenna pole which is on a 16ft pole on our one story roof, so the antenna is about 30 to 35ft above the ground. We would really like to get the major channels. ABC, NBC, CBS, FOX and PBS. We had a rotate-or mounted on the pole that is no longer working and are considering getting a new one but I wanted to check with your experts before I spent any more money on our system. I would greatly appreciate any information that might help our situation. Thank youhttp://www.tvfool.com/?option=com_wr...9900fdf3e64780
mapreston is offline   Reply With Quote
Old 2-Aug-2012, 3:57 PM   #2
Tv Reception.
The link to the tvfool radar map report is not working.
Use the Exact address to make the tvfool radar map report.
And eneter in the height of the antenna when making the radar map report.
What is the distance of tree from house??
Old 2-Aug-2012, 11:08 PM   #3
mapreston
Thank you for your reply and I am sorry if I am not entering the correct info. I know as much about computers as I do antennas. I will try this again with the radar report and hope it works this time. The trees are about 40 feet from the house in all directions and we will have one tv hooked up. This is the address given the last time I tried the map. http://www.tvfool.com/?option=com_wr...9900d4de169b3d
Old 3-Aug-2012, 12:21 AM   #4
Tv Reception.
Based on the provided tvfool radar plot report and channel list.
The receivable Tv stations/channels to the north east are UHF Tv channels.
Install a UHF Tv antenna.
Aim a Winegard HD9095P UHF antenna with a antennas direct CPA-19 preamp at about 57 degree magnetic compass.
Thats the weakest signal strength Tv station WFUP channel 45 FOX , that is in between the stronger Tv stations on either side.
For 2 Tv's connected use a ,
HFS-2D , 2 way splitter.
For 3 Tv's connected use a ,
HFS-3D , 3 way splitter.
The HFS splitter pass power from the power supply/power injector from inside the house to the actual preamplifier mounted close to the antenna.
http://www.hollandelectronics.com , and also at , http://www.solidsignal.com
Most likely adjustments will be made. , the Final antenna height and Final aim direction.
For best reception.
I do not think a antenna rotator will be required.
IF a antenna rotator is required , CM9521A.
As always , trees and tree leaves do a great job of reducing or blocking Tv reception.
Mount the antenna where there is the least amount objects in the way of reception of a span from 10 degree magnetic compass to 90 degree magnetic compass.
Here are some places to buy antennas and etc. , http://www.solidsignal.com , http://www.winegarddirect.com , http://www.amazon.com.
The Tv/s Must Channel Scan for Digital Broadcast Tv Channels sometimes named the 'Air Channels' or 'Antenna Channels' in the Tv setup menu because the Tv transmissions travel through the air from the transmitting antenna to the receiving antenna.
Old 3-Aug-2012, 12:37 AM   #5
Tv Reception.
For your consideration here are some other antenna mounts.
http://www.ronard.com/Tripods%200703/4712.html , http://www.ronard.com.
Here is a light weight aluminum , lay over tower , do antenna installation and adjustments , standing on the ground.
http://www.palcoelectronics.com/pe300.aspx
Old 3-Aug-2012, 1:30 AM   #6
mapreston
Wink
Thank you for your prompt reply and specific info for our situation. We're going to start shopping and try your advice. I will let you know how it works out. Thanks again, I really appreciate all of your time.
