Old 3-Sep-2012, 12:48 AM   #1
ryandean
360 antenna or directional
Hi,
here is my report.
http://www.tvfool.com/?option=com_wr...e77956a7b935a4
Tried indoor antenna before I found this website with no success. Now I started using the RCA ANT800R flat panel digital antenna, seems to work pretty well for not having to rotate anything and not having a huge antenna on the roof.
The two stations I thought I'd get but am not are channels 11 and 13. Is this antenna just too weak and if so what would be a recommendation for best antenna for my location. Not sure the range on the RCA and it's relatively flat here in west michigan.
Thanks so much!
Ryan
ryandean is offline   Reply With Quote
Old 3-Sep-2012, 1:12 AM   #2
thom
11 and 13 are significantly weaker and on a different heading) than the other VHF channels you do get. I don't think the antenna will pull VHF as well as it does UHF.
The report also shows your antenna being 30 above the ground. Is that accurate?
How far is the power supply from the antenna?
thom is offline   Reply With Quote
Old 3-Sep-2012, 1:16 AM   #3
ryandean
Thanks tom. Probably more like 15feet. It's just currently resting up on the roof.
Power supply? There is what I'd call a small amplifier that came with the antenna, that's the only thing that plugs in to power. But that is on a small coax lead right at the tv.
Old 3-Sep-2012, 2:30 AM   #4
thom
The reason I asked about the power supply (amplifier) is this: http://www.amazon.com/review/R19573D...re=electronics
(last paragraph)
Post a link to a new report with 15 ft elevation so we know what we're looking at.
Have you tried re-orienting the antenna at all?
The trouble with this style of antenna is you risk overamplifying the strong signals of which you have some. A decent passive antenna might be a better choice for you. If you were attracted to the RCA because of the small form factor, you might find something like a DB2e (or DB4e) with a dipole add-on palatable.
http://www.solidsignal.com/pview.asp...-Antenna-(DB2E)
http://www.solidsignal.com/pview.asp...sku=5374800141
http://www.antennasdirect.com/store/...-Assembly.html
If you can handle a screw driver you can take apart the reflector assembly and put the dipole on the back of the DBe (screw hole is already there). It's a compact but potent combination, and the dipole is very effective on 11 and 13. I'm pulling 11 and 13 from almost 100 miles away with the exact same dipole (though I wouldn't have believed it if I hadn't seen it myself).
However, that's all speculative until you post an updated report.
Old 3-Sep-2012, 3:17 PM   #5
The following is a Teleview - Recommendation for Digital Broadcast Tv Reception.
Above the roof install a Clear Stream 2 Complete UHF/VHF antenna aimd at about 160 degree magnetic compass direction. http://www.antennasdirect.com/store/...VHF-Combo.html.
For 1 tv connected use no splitter.
For 2 Tv's connected use common simple 2 way splitter.
____________________________________________________
These Digital Tv stations/channels will be received.
WXMI REAL Digital UHF channel 19 , virtual number (17.1-2-3) Fox and Antenna Tv and This Tv.
WOOD-DT REAL Digital VHF channel 07 , virtual number (8.1-2-3) NBC and MyNetwork and Local Weather.
WWMT REAL Digital VHF channel 08 , virtual number (3.1-2) CBS and CW.
WOTV REAL Digital channel UHF 20 , virtual number (41.1-2) ABC and The Cool Tv.
WLLA-DT REAL Digital UHF channel 45 , virtual number (64.1-2-3) My Family Tv , RTV= Retro Tv Network , Family Network.
WOLP-CD REAL Digital UHF channel 41 , virtual number (27.1-2) MyNetwork and Local Weather.
WGVU-TV REAL Digital VHF channel 11 , virtual number (35.1-2-3) PBS.
WZPX-DT REAL Digital UHF channel 44 , virtual number (43.1-2-3) ION Tv.
WZZM REAL Digital VHF channel 13 ,virtual number (13.1-2) ABC and Local Weather.
__________
WXSP is the same as WOLP.
__________
WUHQ is Daystar Religion , WTLJ is Religion , these 2 Tv stations are to the back of antenna (north west) and are strong signal strength and will most likely be received through the reflector screen of the antenna , if not and you will like to receive them , then remove the reflector screen of the antenna.
Here are some roof top antenna mounts , http://www.ronard.com/909911.html , http://www.ronard.com/34424560.html , http://www.ronard.com/ychim.html , http://www.ronard.com.
Here are some places to buy antennas and etc. , http://www.solidsignal.com , http://www.antennasdirect.com , http://www.amazon.com.
Old 3-Sep-2012, 4:35 PM   #6
The following is a Teleview - Digital Broadcast Tv Reception Recommendation.
It is best to install the antenna at a location that has the least amount to no amount of trees and obstructions in the directions of reception.
