Old 9-Sep-2011, 5:35 PM   #1
Jubejube
Digital conversion weak signal
I had 5 channels with a roof mounted round antenna. With the switch to digital I went down to 1 good channel (tvo) and I poor channel CBC. So I hooked up the digital conversion box that I purchased and all I get on the screen is poor signal. My location shows I should be getting a few channels???
Do I need to buy a new antenna and does it need to rotate?
Thanks for any help
Jubejube is offline   Reply With Quote
Old 9-Sep-2011, 5:38 PM   #2
Jubejube
This is my location
http://www.tvfool.com/?option=com_wr...8387e84d7d9a51
Old 9-Sep-2011, 5:56 PM   #3
Please post a link to your TV Fool report. http://forum.tvfool.com/showthread.php?t=4
Old 9-Sep-2011, 6:39 PM   #4
Jubejube
Location
http://www.tvfool.com/?option=com_wr...8387bf94875a00
Old 9-Sep-2011, 6:54 PM   #5
As the other question askers do , Do This --> http://forum.tvfool.com/showthread.php?t=4. When making the tvfool radar report , enter in a height of the antenna and the exact address of the reception location.
Old 9-Sep-2011, 8:44 PM   #6
Jubejube
Radar location
http://www.tvfool.com/?option=com_wr...8387067c345640
I have tried to send this 3 times now... I don't know what is up...
Thank you
Old 9-Sep-2011, 8:49 PM   #7
Does your existing antenna look like this? Omni antenna
How many TVs are or will be connected?
Old 9-Sep-2011, 8:59 PM   #8
Jubejube
Antenna
Not exactly but yes very close to the omni antenna.
Old 9-Sep-2011, 9:08 PM   #9
How many TVs are or will be connected? I'm trying to understand if a rotator would work in your application.
Old 9-Sep-2011, 9:33 PM   #10
A bigger antenna is now needed. After the August 31 2011 , target date , digital transition date , tvfool is showing in the pending applications for digital channels , 3 receivable digital channels to the south west. Pending applications included is also showing receivable Analog Tv stations to the south west and other directions. The digital stations are of weak signal strength , some of the analog stations are stronger signal strength. A antenna and antenna rotor works ok with one tv , however if more the one tv is connected then disagreements will arise over the direction the antenna is pointed. Additional antennas and wiring can be done to supply signal to more then one tv so that every one can receive what they like. So in order to know what antenna situation installation is the best , we needed to know --> how many tv's are/will be connected.
Old 10-Sep-2011, 1:49 AM   #11
Jubejube
One tv
Only one TV..
Old 10-Sep-2011, 5:04 AM   #12
The digital and analog tv transition in Canada is a work in progress , even after the Aug 31 2011 , main transition date. This web site has a list of what digital and analog channels are located where. And may be more up to date then tvfool. One needs to know what current and future digital and analog channel numbers are so one can know the correct antenna to use. http://www.user.dccnet.com/jonleblan...da_TV_stations , http://digitaltv.gc.ca/eng/1282825334983/1282825604404 , http://www.tvtechnology.com/article/117022 , http://www.tvtechnology.com/article/105462 , http://www.digitalhome.ca , http://www.friends.ca , http://www.crtc.gc.ca/eng/home-accueil.htm , http://en.wikipedia.org/wiki/Digital...ion_transition , http://www.saveandreplay.com , http://www.trentondistributors.com
Old 10-Sep-2011, 7:06 PM   #13
I recommend a Channel Master Cm 3016 antenna with a Antennas Direct CPA-19 preamp , mounted on a Channel Master CM9521A rotor.
Old 11-Sep-2011, 3:09 AM   #14
Jubejube
Thanks a million
Thanks for all the advice. I will definitely be purchasing those products and I will update on how it turns out.
Old 11-Sep-2011, 3:27 AM   #15
Jubejube
Cm 3020 deep fringe antenna
Just wondering if the 3020 deep fringe antenna would make any difference or should I stick with the 3016
Old 11-Sep-2011, 5:54 AM   #16
The 3020 is really huge , will require extra bracing and might be more then the CM9521A rotor can handle. You can use the 3018 , it will provide some more reception ability.
Old 12-Sep-2011, 12:33 AM   #17
Jubejube
Lava hd 2605
Thank you,
What about the claims of the Lava HD2605... Comes with a rotor and is so small and cheap...
Is it worth trying?
I know " to good to be true" is just that...usually
Old 12-Sep-2011, 1:05 AM   #18
http://forum.tvfool.com/showthread.php?t=1999 . If it looks like a duck , quacks like a duck , walks like a duck , then it's a duck.
