Old 25-Feb-2016, 2:35 AM   #1
gusmagee
Antenna suggestions
My tv fool report is Located: http://www.tvfool.com/?option=com_wr...51346d852d0acf
I would like to install an attic antenna in my single story home. I would like to run lines to two or three televisions.None of them would be more than 30 feet from the antenna. What antenna would recommend and would you suggest an amplifier?
Thanks
gusmagee is offline   Reply With Quote
Old 25-Feb-2016, 3:28 AM   #2
shoman94
Looks like everything is UHF and all in the same direction. You could get an Antennas Direct DB4e 4 Element Bowtie Indoor/Outdoor HDTV Antenna - 60 Mile Range https://www.amazon.com/dp/B0074H3IU6/ref=cm_sw_r_awd_6iNZwbFD4YDYN
And a cm-3410 (Channel Master CM-3410 1-Port Ultra Mini Distribution Amplifier for Cable and Antenna Signals https://www.amazon.com/dp/B001FY0B90/ref=cm_sw_r_awd_urNZwbF19DJQJ) with a passive 3 way splitter or am active 4 way splitter (4 Port Cable TV/HDTV/Digital Amplifier Internet Modem Signal Booster Internet AMP https://www.amazon.com/dp/B001EKCGT8/ref=cm_sw_r_awd_VvNZwbD721Y5G)
