Old 23-Sep-2014, 5:01 PM   #1
malachi
New to OTA - and not sure what to get. Advice needed.
Hello everyone,
http://www.tvfool.com/?option=com_wr...d2434a726f949c
Just finished looking at my TVFOOL report, and I’m kind of stumbled. Looks like I have three directions I can point at, and pretty far away.
1. This will be an “in-attic” install. HOA and other things. I “could” put it outside, but it would be on the back side of the house, but not above the roof line. At least in the attic it’s out of the weather.
2. Would I need more than one antenna/
3. Could I use a pre-amp?
4. This is a new house. 6 months old. Never got cable, and trying to stay away from it.
Thanks,
I was looking at getting this antenna.
http://www.parts-express.com/antop-v...tenna--210-512
malachi is offline   Reply With Quote
Old 24-Sep-2014, 9:28 AM   #2
Stereocraig
(1) HOA rules regarding antennas, are generally silly and unenforceable.
http://www.fcc.gov/guides/over-air-r...n-devices-rule
HOAs are perfectly aware of this and are just hoping that you aren't.
Signals do not like to travel through building materials and any borderline signals will almost certainly be blocked.
Aiming through the roof from outside, will be even worse.
(2) Yes, multiple antennas or a rotor, depending on whether there will be multiple TVs, or if you're recording.
(3) That depends on the length of cable run, and/ or number of TVs.
(4) P.E.is a great place to do business with, but for antennas, you want to deal w/ a company that specializes in antennas.
Old 24-Sep-2014, 11:41 AM   #3
Point north. The other directions are low power stations. Get a combo UHF/VHF antenna. The PE antenna is not known to me. I'd be looking at an HBU 44 or HD 7694P.
Old 24-Sep-2014, 12:27 PM   #4
That PE antenna is a Chinese import also sold by MCM.
http://www.qiaohua.com/products/v-uhf-272.htm
Old 24-Sep-2014, 1:03 PM   #5
Stereocraig
I forget if it was P.E., or MCM that sold these under the Stellar Labs brand.
I found two of them at a yard sale, unassembled for 5.00 each. I assembled them, but haven't mounted them yet. Probably never will.
The directors are squashed in the center and then tapped into the holes in the beams. They can also work themselves loose.
I guess it would've been too costly to knurl them.
Old 24-Sep-2014, 1:10 PM   #6
malachi
Thanks for the help guys,
Anyone recommend any other antennas?
I forgot to mention, I have a splitter in the attic that would go to two TV's.
Old 24-Sep-2014, 2:49 PM   #7
Stellar is MCM's house brand.
Go with TG's advice. Pick a location that offers the clearest available line of sight to the north. You likely don't need a pre-amp, I'd suggest trying without first. If you run into problems, detail them and someone can make recommendations.
Old 24-Sep-2014, 4:16 PM   #8
malachi
Sweet info guys! Really learning a lot, quickly now.
I’m looking at these two.
Reason is, it looks like I could get a good bit of 7-13 channels.
http://www.mcmelectronics.com/product/30-2440
http://www.mcmelectronics.com/product/30-2415
And I don’t want to have to buy another antenna, but the one TG recommended does not have the range as these two.
One last thing, what about a double bow-tie type, that I can point at different direction at the same time?
Old 24-Sep-2014, 4:41 PM   #9
The first PE antenna has a wider beam width on VHF than the two that I suggested. That means that the gain of the PE is lower, even though the spec says otherwise. I don't believe the PE spec.
Your second choice is a UHF only antenna.
Old 25-Sep-2014, 1:19 AM   #10
I also find it hard to believe those gain numbers from an antenna that short.
