Old 5-Jan-2014, 9:32 PM   #1
dogfluffy
Help with antenna shopping
I was debating attic vs. rooftop antenna, but I'm not sure which is best for me.
http://www.tvfool.com/?option=com_wr...46ae8ef0b40cbe
Thanks in advance
dogfluffy is offline   Reply With Quote
Old 5-Jan-2014, 10:20 PM   #2
If you have a clear line of sight looking east toward Seattle, an attic install may work. Your attic would need to be friendly to RF signals... many are not.
If you have the typical Douglas Fir, Cedar and other native NW trees in the way, step up to the reality that a large combination antenna will be needed.
A premium option would be the Antennas Direct DB8e + Antennacraft Y5713.
A single antenna such as the Antennacraft HBU-33 would be the smallest I'd consider, their HBU-44 & HBU-55 would not be overkill.
Old 5-Jan-2014, 11:48 PM   #3
dogfluffy
I have a rambler style, probably fir T&G decking and composite 3 tab roofing, 2 layers deep. I also have a handy bracket bolted on top of my carport leftover from an old Dish Network bracket and coax I could use fairly easily. I do not have LOS to Seattle. I'm 2 blocks inside wooded areas and furth uphill to housing with about 20'-30' of hill elevation blocking the Seattle side. I already pick up the KCPQ easily to the west with a cheap antenna from Gold Mountian...but I need to upgrade and I was hoping to spend $100 if I can get something pretty solid. I have no idea which antenna would be best suited or what a good price would even be.
Thanks very much for your help.
Old 6-Jan-2014, 3:06 AM   #4
Install a , http://www.antennacraft.net , HBU44 antenna Above The Peak Of The Roof in such a manner that the roof and building are not , obstructing , impeding , blocking , reception in the directions of reception , East , South East , West South.
Here are some Above The Roof antenna mounts.
Buy the ronard antenna mounts at , http://www.soldsignal.com , by typing , ronard(x) , in the solidsignal search box or buy from , http://www.ronard.com.
http://www.antennacraft.net.
http://www.amazon.com.
http://www.solidsignal.com.
http://www.hollandelectronics.com
Aim the HBU44 antenna at about , 67 degree magnetic compass direction.
As always , the starting antenna aim direction is the -->starting antenna aim direction.
The antenna aim direction can be adjusted for best reception.
Most Digital Tv's have a , Signal Strength Meter , and some Digital Tv's also have a , Signal Quality Meter.
Test reception With and Without a , RCA , TVPRAMP1R , preamplifer.
When Testing reception without the preamplifier , disconnect the , preamp unit , power injector , power supply.
Buy the , HFS-2D and HFS-3D , splitters at , http://www.solidsignal.com , or , http://www.hollandelectronics.com.
The Best Practice is to install the HBU44 antenna at a location that has the least amount to no amount of obstructions of any type or kind in the directions of reception.
The Tv's Must Channel Scan for the , OTA=Over The Air , ATSC-Digital Broadcast Tv Stations/Channels , often named the ~ DTV Channels ~ Antenna Channels ~ Air Channels ~ in the Tv Setup Menu because the Tv transmissions travel through the Air from the transmitting antenna to the receiving antenna.
Some digital tv's will Automatic channel scan for cable tv channels.
Go into the Tv Setup Menu and select ~ DTV Channels ~ Antenna Channels ~ Air Channels ~.
Scan for , ATSC-Digital Broadcast Tv Stations/Channels.
Old 6-Jan-2014, 6:44 AM   #5
With wooded terrain above you, you need to consider using a big antenna... Even the combination of an Antennas Direct 91XG + Antennacraft Y10713 is not overkill.
