Old 23-Jul-2013, 9:54 PM   #1
Joetech
Antenna Recommendations
Looking for a good antenna / amp setup for either indoors, attic or small roof mount.
Here's the report:
http://www.tvfool.com/?option=com_wr...46ae60b048fb6c
Thoughts or ideas/suggestions are much appreciated.
Thank you!
Joetech is offline   Reply With Quote
Old 24-Jul-2013, 1:39 AM   #2
The tvfool report shows a antenna height of 5 feet above ground.
Do not delete the 5 foot antenna height above ground report.
Some USA Tv stations might be received with higher antenna heights.
To see what higher antenna heights above ground will receive.
Please make and post 2 more tvfool reports.
25 feet above ground.
40 feet above ground.
______
Also the 5 foot tvfool report says.
Resolved to block level only.
Try and make the 25 and 40 foot reports using the Exact address.
Old 24-Jul-2013, 4:05 PM   #3
Joetech
Thank you for the reply.
I've found the co-ordinates instead of the address and:
25 foot:
http://www.tvfool.com/?option=com_wr...46aec19ee1a68f
40 foot:
http://www.tvfool.com/?option=com_wr...46ae69d8d0fc24
Old 25-Jul-2013, 11:00 AM   #4
For reception of the Canada Digital Broadcast Tv stations/channels.
Above the Roof in such a manner that the roof and house are not impeding and blocking reception to the , West , North West , North East , East.
Install a Winegard HD7697P antenna aimed at about 70 degree magnetic compass direction.
Use the 5 foot tripod antenna mount. ronard(911).
Use the , ronard(4560) eave antenna mount.
Measure the Chimney and use a , ronard(2212) , ronard(2218) , ronard(2224).
_______________________
http://www.saveandreplay.com.
http://www.trentondistributors.com.
http://www.ronard.com.
A antenna system amplifier is not required for Canada reception.
The higher antenna height above 25 feet did not help with signal strength of USA Tv stations.
As a 'Test' , If you will like to try for reception of WICU-TV VHF channel 12 NBC.
Aim the antenna at about 142 degree magnetic compass direction.
For the Test have only 1 Tv connected , no splitters.
Digital Tv Tuners can develop - Digital Glitches - that are not cleared out with simple channel scans.
Do a Double Rescan , http://www.dtv.gov/rescan.html.
________
The Tv/s Must Channel Scan for the , OTA=Over The Air , Digital Broadcast Tv stations/channels , often named the 'Air Channels' or 'Antenna Channels' in the Tv Setup Menu because the Tv transmissions travel through the Air from the transmitting to the receiving antenna.
Some digital tv's will Automatic channel scan for cable tv channels.
Do not channel scan for cable tv channels.
Go into the Tv Setup Menu and select , 'Air Channels' ~ 'Antenna Channels'.
Scan for channels.
_________________________________
Old 27-Jul-2013, 9:53 PM   #5
Joetech
Thank you for the information!!! That's a great help! I'll be mounting an antenna in the next couple of weeks. I'll let you know how it goes.
Old 6-Aug-2013, 3:21 PM   #6
Joetech
Just wanted to say thank you. First scan got 7 channels, on a cloudy day. Upto the top 10 now.
Old 6-Aug-2013, 8:39 PM   #7
You are doing Ok. Thanks for the good report.
If you have more questions , Ok to ask.
Here is a way to receive All of the USA PBS channels and other channels.
The reception is Free.
Buy a Small Dish and Receiver.
Here are places to start.
http://www.ftalist.com.
__
FTA Satellite Tv is receivable in , Canada , USA , Mexico. And most other places around the world.
Last edited by teleview; 8-Aug-2013 at 12:00 AM. Reason: Clarify information and typos.
Old 17-Aug-2013, 2:36 AM   #8
Joetech
Would a pre-amp help at all for any of the other potential channels out there? If so, what should I look at?
I found in my basement (from the old owner) an SST-1-S4SF Drop Amplifier Signal Stretcher by Thomas & Betts, Augat.
It shows 5-42/53-1000MHz. Any idea what this is?
Thank you!
Old 17-Aug-2013, 10:18 PM   #9
http://service.egg.com.tw/twoway/product/SST.pdf.
Looks like the amplifier gain is 15 dB. That is a low gain figure.
That is Ok because the Local Canada Tv stations are , 1.5 ~ 5.7 , miles away and strong to medium strong signal strength.
So a lower gain amplifier is Ok to use as a 'Test' amplifier.
The amplifier might help with reception of the USA , NBC Tv station.
