Old 19-Jan-2013, 4:59 PM   #1
dplav
cutting the cord, need help!
http://www.tvfool.com/?option=com_wr...1dda9ad4dbc72b
I have 3 Panasonic HD tv's. Master Bedroom 1, bedroom 2, basement rec room for entertaining 3. Do I need a converter? I was thinking of going with 2-3 Roku's. Master bedroom, we watch most of the tv shows here. Bedroom 2,-my son's bedroom, he loves watching cartoons and nba games. Basement rec room-entertaining area for guests.
I tried using an antenna like this in the past, but the reception was very spotty on a cloudy day.
http://www.bestbuy.com/site/RCA+-+Am...&skuId=8280843
I was thinking of going with this antenna.
http://www.amazon.com/Terk-Amplified...pr_product_top
or this one:
http://www.amazon.com/Paper-Thin-Lea...s=hdtv+antenna
Anything else I need to know that would help us out?
dplav is offline   Reply With Quote
Old 19-Jan-2013, 8:24 PM   #2
One antenna would be enough to serve all the TVs. Connected to a splitter, the antenna's signal can be distributed using existing coax if it has been disconnected from cable or satellite service.
I would avoid an amplified antenna. The signal strength available to you may be enough to overload an amplifier.
Any small to mid-size 'All-Channel' antenna will serve well;
Antennacraft C290
Channel Master CM-3016
Winegard HD7010
Mounted outdoors, pointed due east you'll have plenty of signal. You may be able to get good reception in an attic, but outdoor mounting ensurers success.
TVs built and sold since mid-2007 should be equipped with over-the-air tuners. That would make a convertor unnecessary. Simply change the tuner from cable mode to 'air' or 'antenna'. Then scan for channels... check your manual for the exact instructions for your TV.
Old 19-Jan-2013, 8:37 PM   #3
dplav
Antennacraft C290
Winegard HD7010
Thanks. The problem is that I'm not to much of a handyman to know how to hook it all up that way.
Old 19-Jan-2013, 9:46 PM   #4
dplav
Antennacraft C290
Winegard HD7010
Could you give me an idea of what work without me having to mount anything outside?
Old 20-Jan-2013, 12:11 AM   #5
Indoor Tv reception is Not a reception friendly environment and Never Will Be a reception friendly environment.
Signal attenuation and (multipath) reflected signals bouncing all around is not reception friendly.
For a indoor type antenna use Terk HDTVi (not the HDTVa) , aim the HDTVi antenna at about 90 degree magnetic compass direction. East.
Here is how to aim indoor antennas and outdoor antennas , http://www.kyes.com/antenna/pointing/pointing.html.
To improve the reception put the HDTVi antenna in/at a window or patio/balcony window that is to the east.
If the Tv is not close to the HDTVi that in/at the window then run a loooong coax from the HDTVi to the tv.
The Tv Must Channel Scan for the Digital Broadcast Tv Channels , often named the 'Air Channels' or 'Antenna Channels' in the Tv setup menu because the Tv transmissions travel through the air from the transmitting antenna to the receiving antenna.
Go into the Tv setup menu and select , 'Air Channels' or 'Antenna Channels'.
Go into the Tv setup menu and select , 'Air Channels' / 'Antenna Channels'.
________________________________________________________________
Attics Are Not a reception friendly environment and Never Will Be a reception friendly environment. Signal attenuation and (multipath) reflected signals bouncing all around is not reception friendly.
For a antenna installed in the attic , install a Winegard HD7000R antenna aimed at about 90 degree magnetic compass direction. East.
No preamplifier is required.
As always , trees and tree leaves do a good job of , reflecting , reducing , blocking Tv reception and so do buildings and other obstructions including your own roof and house.
It is best install the HD7000R antenna at a location that has the least amount to no amount of obstructions of any type or kind in the directions of reception including your own roof and house.
Here are some places to buy antennas and etc. , http://www.solidsignal.com.
http://www.amazon.com.
Old 20-Jan-2013, 8:09 PM   #6
rickcain
Get the biggest antenna you can fit into your attic. Reception drops considerably when your antenna has to go through the wood and shingles of your roof, plus its lower than if it were on the roof. That also negates the need to have a signal amplifier.
Stay away from anything Terk, they're poorly performing antennas. Also avoid eBay antennas which claim 120 mile range which is impossible. They're junk plastic antennas made in China and are worth about $5 each.
rickcain is offline   Reply With Quote
Old 21-Jan-2013, 4:00 PM   #7
dplav
The other concern is the reception in our basement rec room. What would be best downstairs?
Old 21-Jan-2013, 7:00 PM   #8
dplav
I need to find a local installer to install the antenna in the attic. Where should I start looking?
Old 21-Jan-2013, 7:15 PM   #9
For the best reception install the HD7000R antenna above the roof in such a manner that the roof or house is not blocking reception to the East , at about 90 degree magnetic compass direction.
Here are some above the roof antenna mounts , http://www.ronard.com/909911.html if using a tripod antenna mount use the 5 foot tripod.
http://www.ronard.com/34424560.html if using the eave antenna mount use the #4560.
http://www.ronard.com.
______________
Can also use a Winegard DS3000 J type antenna mount.
Old 23-Jan-2013, 3:58 AM   #10
dplav
I was quoted $280-$380 to have an antenna installed in my attic which would connect to all three tvs. The installer told me the price variation is for labor, since he doesn't know how much is involved.
Old 23-Jan-2013, 4:23 AM   #11
~$280.00 to ~$380 to have the HD7000R antenna installed.
Compared to.
The average price of Pay Cable and Pay Satellite is as an Example $100.00 a month.
That is $1,200.00 a year.
That is $2,400.00 for 2 years.
And so forth.
What concerns me is the word -->an.
In the wording , to have - an - antenna installed.
Old 23-Jan-2013, 9:04 PM   #12
How is that a concern? Should the estimate be for more than one antenna or are you cautioning the OP to specify the exact make and model of the antenna?
Old 23-Jan-2013, 9:44 PM   #13
Stereocraig
OT, but you must live by the village park and the lake, cause your TVF looks similar my daughter's.
Old 24-Jan-2013, 12:07 AM   #14
My concern is that the question asker receives the Tv channels that are available to receive to the Main group of Tv stations/channels to the East direction.
The antenna and antenna system I have recommended will do that , for the Main group of Tv stations/channels to the East direction.
Not all antennas and antenna systems are the best for reception every where at all locations.
An , antenna and antenna system that some one else recommends may or may not be the correct antenna and antenna system for reception of the receivable Tv stations/channels to the Main Group of Tv stations/channels to the East direction.
Old 26-Jan-2013, 7:04 PM   #15
dplav
Compared to.
And so forth.
$100 is what I pay with 12mb internet. If I take TV out the internet cost goes up to $54.
Old 26-Jan-2013, 7:07 PM   #16
dplav
I'm 10 min East of the lake
Old 26-Jan-2013, 7:19 PM   #17
dplav
http://store.gomohu.com/the-leaf-ind...v-antenna.html
What would be wrong with trying this out?
35 mile range. I am well within that range.
Old 26-Jan-2013, 8:57 PM   #18
elmo
It's a UHF design only so it won't pick up your available VHF channels. And it's nothing magical. They call it omni-directional because there's no reflector, but it's reception will vary based on direction it faces. If you have a broadcast tower nearby, it doesn't require much antenna to pick it up well. For 35 miles, it has to be an optimal situation; I doubt they disclose that test scenario. It could work for you, but just be ready to return it. Slick marketing. I like the part about "designed after a military mudflap antenna." I guess the military likes to watch TV while out and about?! Not hardly. It's like saying a Toyota Camry is based on race car design because it has cylinders and gears too. Who knows what a military mud flap design is used for. I could be for near field communications on a specific frequency, which would not be optimal for a TV application. So like I said, if you are inclined to try it, be aware of the return policy. If you're a bit crafty, there's always the "build your own moho" for just a couple of bucks. http://www.instructables.com/id/Yet-...dtvsecretscom/
Yeah - it's virtually the same thing - same design, for sure. I can say I actually did this little project the first time I started looking into antennas. It took little time to assemble and I attached it to the back of the TV. It did ok, but nothing like the outdoor antenna I eventually got. But it was fun to do.
As for the expense of getting an antenna installed, when you cut the cord, you can afford to spend a little as the savings will pile up in the long run.
Old 26-Jan-2013, 9:57 PM   #19
dplav
Here's what I tried without having much luck watching locals on a cloudy day. It was choppy.
http://m.bestbuy.com/m/e/product/det...=1171058630563
If I didn't have luck with this should I even try the Leaf?
Old 27-Jan-2013, 6:44 PM   #20
dplav
I just read that Roku partnered up with TimeWarner to provide even more programming on the Roku. Interesting.
