Old 5-Sep-2012, 3:09 AM   #1
Hico
Rural install help
Looking for setup recommendation. Got 8.1, 8.2 and 8.3 only using a standard outdoor antenna mounted 20 feet up using a signal amp from Walmart. I attached a location map. Dfw is 66 miles away. I am surrounded by trees. Antenna amp and pole height help is appreciated. The 8.1 picture was fantastic. 37 percent signal strength.
Hico is offline   Reply With Quote
Old 5-Sep-2012, 4:38 AM   #2
Please do as the other question askers do and make and post a tvfool radar report.
Little will happen with out a tvfool radar plot report.
Use the Exact address and make the antenna height 25 feet.
Of the antennas pictured what antenna looks the most like the one you have.
http://www.kyes.com/antenna/pointing/pointing.html
What is the make and model number of the antenna??
What is the make and model number of the signal amp??
Last edited by GroundUrMast; 14-Nov-2012 at 5:27 AM. Reason: Deleting off-topic content
Old 5-Sep-2012, 1:02 PM   #3
Hico
Here are the coordinates
31.913556,-98.134947 * antenna height: ft (above ground level)
Having trouble with the report on this iPad
One tv
Old 5-Sep-2012, 2:22 PM   #4
Hico
here is the report:
http://www.tvfool.com/?option=com_wr...e7790b5d7a5a35
this link is not opening:
the antenna looks likes this:
http://i.walmartimages.com/i/p/00/07...82_500X500.jpg
bought it for a buck at a garage sale.
Old 5-Sep-2012, 2:26 PM   #5
Hico
here is the spec on the signal amp:
.The GE Video Signal Amplifier improves signal strength for cable or antenna connections. This signal amplifier features a return path of -24dB.
GE Video Signal Amplifier:
•Improves video signal strength
•-24dB return path
•Model# 33341
Model No.: 33341
Product in Inches (L x W x H): 4.25 x 2.0 x 5.0
Walmart No.: 007212642
Old 5-Sep-2012, 5:46 PM   #6
The house with what looks like a blue roof from above , that is south of the curve part of the road CO RD 122 , and west of Honey Creek Cemetery.
The signal strengths are very weak but receivable.
The Digital Tv stations/channels to the north east at about 52 degree magnetic compass direction should be receive down the channel list to at least KDFI-DT REAL Digital UHF channel 36 , virtual number (27.1) MYNetwork.
The antenna will be mounted above the roof of the house no less then 25 feet above ground and 40 feet or as close to 40 feet would be better.
The antenna is aimed at about 52 degree magnetic compass direction.
Install a Winegard AP8275 preamp.
When the AP8275 preamp is installed do not use the little GE amp.
For one Tv connected use no splitter.
If you decide to connect more Tv's.
For 2 Tv's connected use a HFS-2D , 2 way splitter.
For 3 Tv's connected use a HFS-3D , 3way splitter.
For 4 Tv's connected use a HFS-4D , 4 way splitter.
Buy the HFS splitters at , http://www.hollandelectronics.com or http://www.solidsignal.com.
Here are some above the roof antenna mounts , http://www.ronard.com/909911.html , http://www.ronard.com/Tripods%200703/4712.html , http://www.ronard.com.
Here are some places to buy , http://www.solidsignal.com , http://www.amazon.com , http://www.winegarddirect.com.
As always , trees and tree leaves do a real fine job of reducing or blocking Tv reception and so do buildings and other obstructions in the direction of reception.
It is best to instatall the antenna at a location that has the least amount or no amount of obstructions in the reception path of the antenna.
The Tv/s Must Channel Scan for The Digital Broadcast Tv Channels , sometimes named the 'Air Channels' or 'Antenna Channels' in the Tvsetup menu because the Tv transmissions travel through the air from the transmitting antenna to the receiving antanna.
Here is a free standing no guy wires , light weight weight aluminum , lay over tower , do antenna instal and adjustments standing on the ground.
http://www.palcoelectronics.com/pe300.aspx
Last edited by GroundUrMast; 14-Nov-2012 at 5:28 AM. Reason: Deleting off-topic content
Old 5-Sep-2012, 6:25 PM   #7
Hico
so you think the antenna is fine? I see no recomendation to replace.
Old 5-Sep-2012, 6:56 PM   #8
Yes I think the antenna you have will work Ok.
If a more powerful antenna is required then use a Winegard HD7698P.
Ground Ur Mast says he deleted off topic content , yet nothing was deleted , not even one letter of the alphabet.
Last edited by teleview; 14-Nov-2012 at 7:29 AM. Reason: Deleting off-topic content
Old 14-Nov-2012, 12:29 AM   #9
Hico
finally got the antenna on a 40 foot pole with the amp from solidsignal installed. pointed at 52 degrees as instructed. getting 29 channels total, 5,8,11,21 all in 1920 x 1080. 4 is coming in at 720. Impressed considering the distance from towers plus the location is in a low area. Appreciate your assistance!!!
Old 14-Nov-2012, 7:53 AM   #10
Yes very impressive , with all those Tv stations 80 some miles away.
Yes KDWF REAL Digital UHF channel 35 , virtual number (4.1) FOX.
Yes FOX does transmit a high definition signal of 720P.
The picture clarity definitions are ,
standard definition 480i
standard definition 480P
High definition 720P
High definition 1080i
High definition 1080P
You can research the signal definitions ( picture clarity , how many lines make the picture ) on the internet.
