Old 16-Aug-2012, 2:21 AM   #1
SamIAm
Advice on Antenna Type and Direction
Hello-
I am seeking some advice on the type of antenna I need and also which direction that would be most beneficial for my situation. Based on what I have researched and read, I assume I will need to purchase a large directional antenna with Pre-Amp. I am most interested in the four major networks (CBS,NBC,ABC,FOX). The antenna will be mounted approximately 22' above ground with surrounding trees.
Here is my tvfool report: http://www.tvfool.com/?option=com_wr...9900e53fc20b5d
Is there a specific antenna manufacturer rated better than others?
I currently have cable ($125 a month) and would like to cut the cord and only pay for Internet which I calculate will save me around $60.00 a month.
Any suggestions or advice will be greatly appreciated.
SamIAm is offline   Reply With Quote
Old 16-Aug-2012, 5:11 AM   #2
Tv Reception.
For reception of the Digital Tv stations/channels to the , south west , south , south east.
The Networks you have listed and many more digital Tv stations/channel will be received.
Above the roof , Install a Winegard HD7696P antenna with a Winegard AP8700 preamp , aimed at about 190 degree magnetic compass direction.
For 2 Tv's connected use a HFS-2D , 2 way splitter.
For 3 Tv's connected use a HFS-3D , 3 way splitter.
Buy HFS splitters at.
http://www.hollandelectronics.com , also at , http://www.solidsignal.com.
Here are some Strong and Sturdy antenna mounts , http://www.ronard.com/909911.html , http://www.ronard.com/34424560.html , http://www.ronard.com/ychim.html , http://www.ronard.com.
Here are some places to buy antennas and etc. , http://www.solidsignal.com , http://www.winegarddirect.com , http://www.amazon.com.
As always , trees and tree leaves do a real fine job of , reducing or blocking Tv reception and so do buildings and other obstructions.
Mount the antenna at a location that has the least amount or no amount of obstructions.
Old 16-Aug-2012, 12:14 PM   #3
SamIAm
Thanks for your time and information. This is very helpful.
