Old 9-Aug-2018, 8:15 PM   #1
pbyers
Operational Questions
WQED, RF & Virtual Channel 13 has been missing from the Pittsburgh DMA Signal Locator for several months. Can someone fix that please?
Old 10-Aug-2018, 12:39 AM   #2
JoeAZ
WQED, PBS Pittsburgh is one of many stations missing.
Slowly, very slowly, stations that were missing are being
added.............
Old 10-Aug-2018, 1:19 AM   #3
Welcome to the forum, pbyers
Yes, WQED is missing from TVFool reports because there are errors in the database used to generate reports as a result of many repack changes. I doubt that TVFool will make corrections because they have a small staff.
Here is a report for Pittsburgh with WQED missing:
http://www.tvfool.com/?option=com_wr...9038ac4327853b
This report from rabbitears.info shows WQED:
https://www.rabbitears.info/market.p...&callsign=WQED
This shows the repack changes for the Pittsburgh DMA. Note that WQED will move to VHF-Low channel 2, which requires an antenna with large elements. There is a high noise level on VHF-Low from electrical interference, which will create a reception problem for some viewers.
Most of the changes will be during Phase 4:
Testing Begins: 6/22/2019 Phase Ends: 8/2/2019
https://www.commlawcenter.com/2017/0...deadlines.html
Old 10-Aug-2018, 1:52 PM   #4
pbyers
FYI, WQED will be moving to VHF channel 4 in Phase 4 (CP granted 8/7/18).
Old 10-Aug-2018, 5:56 PM   #5
That's better.....
All parts of rabbitears.info haven't been updated but it does show here:
https://www.rabbitears.info/tvq.php?...ms&facid=41315
and on the tower lineup:
https://www.rabbitears.info/tower.ph...e&asrn=1022324
I see the WQED tower, but what is that white "pillow" behind it?
Old 10-Aug-2018, 6:49 PM   #6
Inflatable building aka "air-supported dome". Since that one is near the athletic fields, it's probably being used as a facility for the sports teams or other sports activities. They're quick to put up and cost considerably less than more traditional construction.
Old 10-Aug-2018, 11:08 PM   #7
Ah, so! Thank you!
