Old 27-May-2011, 2:15 PM   #1
Esteban
Will Winegard 8200u be a good choice ??
I have received advice from experts here before concerning my friend's location at bottom , on a previous thread . There are high trees in the area but there is a nice gap between them at 78° . I tried my CM4228 on the ground & at 6ft level & was getting a few channels. I am offered a " Winegard 8200u , if I take it down. Do you guys think this is a good antenna choice & at least as good as HBU44, or WG 7600 series as was recommended before ??? Mounted above roofline , one HD TV, asphalt shingles, nothing else .
Thanks a lot for all the help.
http://www.tvfool.com/?option=com_wr...8d1799c033de3c
Old 27-May-2011, 5:20 PM   #2
Originally Posted by Esteban View Post
The link doesn't work. This is the one posted previously:
The 8200 will work fine but it's much larger than necessary.
Old 27-May-2011, 7:03 PM   #3
TV Antennas and Reception
It is better to continue the previous post , it is not a good idea to start a new post each time.
Old 27-May-2011, 7:20 PM   #4
The Winegard 8200U will work Ok. It is a Heavy Duty Construction antenna and is a Big All Channel Antenna. It is a good idea to put the 8200U on a Strong Mount such as a , tripod mount , chimney mount , peak of the roof eave mount.
Old 28-May-2011, 12:17 AM   #5
Esteban
Thanks guys. I am going to get it tomorrow.
