Old 26-Mar-2015, 2:35 AM   #1
seemore
The Best OTA Antenna For Clinton MD
[INDENT] I am seeking help to find an OTA antenna in the Clinton MD area that will provide the best reception for the most channels. My location reference is:
http://www.tvfool.com/?option=com_wr...f1f016e8ab8a21
I really want the major network news for this area.
Thanks for any assistance you can provide.
seemore is offline   Reply With Quote
Old 26-Mar-2015, 11:41 AM   #2
No static at all
No static at all's Avatar
A very simple, inexpensive solution would be a roof mounted HBU-22 antenna to capture the DC stations. This should easily drive up to 4 TV's with no amplifier.
You may even be a candidate for an attic mounted antenna, if aimed directly through the roof with no closeby metal or other obstructions.
Old 27-Mar-2015, 2:26 AM   #3
seemore
Thanks for the help. Is there another option that will reach stations a little further out than DC?
Old 27-Mar-2015, 12:05 PM   #4
Sure, but, there's no free lunch. An antenna capable of picking up weaker, more distant channels will be much larger, heavier, and more directional which means you need a heavier-duty mount, higher in the air, and a rotor capable of re-aiming the antenna remotely.
Old 27-Mar-2015, 12:12 PM   #5
No static at all
The HBU22 should at least get the UHF channels from Baltimore (ABC, Fox, CW) if aimed more in that direction. If you want NBC 11 & CBS 13 you will likely need to go up to an HBU33 or better yet HBU44.
You might be able find to a sweet spot between DC & Baltimore where you can aim the antenna & get both w/o needing a rotator.
Old 5-Apr-2015, 9:17 PM   #6
seemore
Thanks again.
Can you provide information for the larger/heavier antenna that has a rotor for redirection.
I want to take advantage of all my options before making a final decision.
Best regards
seemore
Old 6-Apr-2015, 6:42 PM   #7
I'd start with an ANT-751. Aim it roughly north. If that works, you're all done. If not, add a DB-4e coupled to the ANT-751 using a UVSJ. The DB-4e gives you a wide pattern with extra gain on UHF.
Old 9-Apr-2015, 9:36 PM   #8
stvcmty
You don’t need much antenna in the UHF band. A HBU22 is a good candidate to find a sweet spot where the Baltimore and DC stations come in without a rotor. The HBU should also get 7 and 9 from DC. [Assuming the DC/Baltimore UHF’s come in on the HBU22, as well as 7 and 9, then a separate high VHF Yagi could be used to get 11 and 13 from Baltimore (such as a Y5-7-13) and a channel 12 jointenna (if you can find one) to merge the antennas .]
Analog 6 is being used as a Spanish radio station.
Real 42, 29, and 28 all have the same 3 subchannels, so you only need 1. Real 34 and 12 have the same subchannels, so you don’t need to worry about 12.
