Old 25-Mar-2015, 12:52 AM   #1
czmike
Choice of antenna
I know this is a favorite topic from reading other posts.
Here's my location report: http://www.tvfool.com/?option=com_wr...f1f067e47761cd
I plan on using existing cable wiring but will aim to remove some un-needed runs, hoping to hit 4 TVs.
I will attic mount- the location is fairly uncluttered and about 35 feet above ground level and I have no choice or desire for external.
Channel 6 is important to me and I assume will be the greatest challenge.
With a simple amplified Leaf antenna against a window, I am able to receive virtual 3, 10, 17, 23, 35, 57 and sometimes more, along with their sub-channels, at just above ground level on the first floor.
Antenna I am considering include the Winegard HD7694P, the RCA ANT751, or the CM-4228HD.
I appreciate any advice as Fios is up for renewal and I'm ready to cut cable, Thanks!
czmike is offline   Reply With Quote
Old 25-Mar-2015, 4:31 PM   #2
In order to pick up ABC on channel 6 you need an antenna capable of low band VHF. One such antenna is the HD 7084P. None of the antennas that you mention will get ABC.
Old 25-Mar-2015, 5:21 PM   #3
Stereocraig
I would never install a UHF only antenna and expect to receive any VHF channels, but it can happen.
I have a 91XG and a DIY bowtie and both, will receive real 5 at 39.7mi LOS.
Old 26-Mar-2015, 11:17 PM   #4
czmike
So..., if I gave up on channel 6, Would you recommend the CM-4228HD?
