Old 13-Feb-2014, 1:54 AM   #1
GDeane
Antenna Selection - Greeley, CO
Looking for advice on an antenna. Planning to install in the attic. Just need CBS, NBC Fox, ABC and PBS. Two televisions.
http://www.tvfool.com/?option=com_wr...5b941ecbd3b50d
GDeane is offline   Reply With Quote
Old 13-Feb-2014, 7:35 AM   #2
Attics Are Not a reception friendly environment and Never Will Be a reception friendly environment.
Start with a , www.antennacraft.net , HBU11K antenna in the attic , aimed at about 220 degree magnetic compass direction.
The Tv signals strengths are strong at your reception location.
A antenna system amplifier is not required.
For 4 Tv's connected use a simple common 4 way splitter.
If reception situation/problems happen in the attic that are not resolvable with antenna aim and location adjustments in the attic.
Then move the HBU11K antenna to above the roof the peak of the roof in such a manner that reception is not , obstructed , impeded , blocked , by the attic , roof and building in the directions of reception.
The directions of reception at your location are , the main group of Tv stations to the South West , and other directions of reception to the , West , North West , North , South East.
As always , trees and tree leaves , plants and plant leaves , buildings and other obstructions have a Negative Effect on Broadcast Tv Reception.
Absorbing and Blocking Reception.
The Best Practice is to install the , HBU11K antenna at a location that has the least amount to no amount of obstructions of any type or kind in the directions of reception including your own roof and building.
Last edited by teleview; 14-Feb-2014 at 12:42 AM. Reason: Clarify information and typos.
Old 14-Feb-2014, 1:29 AM   #3
GDeane
Thanks for your help. Will see if HOA will allow me to roof mount the HBU11K.
Old 14-Feb-2014, 5:24 PM   #4
GDeane
Old 14-Feb-2014, 5:26 PM   #5
GDeane
Thanks for the help. Think I will look at installing on the roof. Just need to double check with HOA.
Old 15-Feb-2014, 6:30 AM   #6
Here is the Federal Antenna Law that says Yes you and every one can install a Broadcast Tv Antenna of Any Size Above The Peak Of The Roof so as to have Reliable Reception.
Hoa's are well aware of the Federal Antenna Law.
And some Hoa's are thinking your are not aware and even if you do become aware of the Federal Antenna Law , you will not understand the Federal Antenna Law.
That the Federal Antenna Law says Yes you can install Broadcast Tv Antennas of Any Size Outside Above The Peak of the Roof in such a manner so as to have Reliable Reception , and you do not have to hide the antenna and you do not have to contact the Hoa.
You do not have ask the Hoa for permission or even contact the Hoa about installing a Broadcast Tv Antenna above the roof so as to have Reliable Reception.
www.fcc.gov/mb/facts/otard.html
http://www.fcc.gov/guides/over-air-r...n-devices-rule
Last edited by teleview; 16-Feb-2014 at 11:20 PM. Reason: Clarify information and typos.
Old 15-Feb-2014, 11:17 PM   #7
GDeane
You're right regarding the HOA and the FCC law. I checked with ours just in case. The HBU11K looks like a good choice. I do plan to mount the antenna on the roof rather than in the attic now that I know the HOA will not be a problem. Any thoughts on the Antenna Craft HDX1000?
Old 17-Feb-2014, 3:00 PM   #8
GDeane
Free at last! No more cable. Picked up a HDTV and an indoor Terk Antenna. I get 19 channels which is fine for now. Will switch to a better antenna once it warms up.
Old 18-Feb-2014, 1:59 AM   #9
Concerning the HDX1000 and other amplified antennas for reception at your location.
A amplified antenna -->Is Not<--required at your reception location of the Tv stations in the Green reception zone and most if not all of the Yellow reception zone.
If a antenna system amplifier is required , then one can be added at a later date.
Last edited by teleview; 19-Feb-2014 at 5:28 PM. Reason: Clarify information and typos.
Old 18-Feb-2014, 6:06 PM   #10
GDeane
Good to know. I still can't pick up ABC, so I will try the HBU11K antenna on the roof. Maybe it will pick up those "Green" signals including ABC.
