Old 24-Jan-2014, 2:50 AM   #1
Kinetic
Antenna/Amp recommendation for OTA
Sginal Analysis:
http://www.tvfool.com/?option=com_wr...5b94e6bc1ec164
Looking to receive OTA channels. Antenna will be mounted 25 ft or so from the ground.
Thanks in advance!
Kinetic is offline   Reply With Quote
Old 24-Jan-2014, 6:54 AM   #2
An RCA ANT-751 would be good option. The Antennacraft HBU-11, HBU-22 and HBU-33 would fit the application. The Winegard HD7694P would be a premium option, quite capable of driving several sets with no amplifier needed.
Old 24-Jan-2014, 7:16 PM   #3
Install a , www.antennacraft.net , HBU33 , Above The Peak Of The Roof aimed at about 19 degree magnetic compass direction.
A antenna system amplifier is not required.
For 4 Tv's connected use a simple common 4 way splitter.
www.ronard.com/909911.html
www.ronard.com/34424560.html
www.ronrad.com/ychim.html
Measure around the chimney and Use a , ronard(2212) , ronard(2218) , ronard(2224) .
Last edited by teleview; 25-Jan-2014 at 3:18 AM. Reason: Clarify information and typos.
