Old 4-Dec-2013, 5:02 PM   #1
fkgrable@aol.com
New OTA hook-up
Would like input as to appropriate antenna, location, height, indoor or out, etc. for the below analysis.
http://www.tvfool.com/?option=com_wr...46ae0c702ae16e
Thanks
fkgrable@aol.com is offline   Reply With Quote
Old 4-Dec-2013, 10:26 PM   #2
Lot's of easy to receive signals per your report...
I'd mount an RCA ANT-751 above the roof, pointed west. If you have trouble with reception of the signals from the east, rotate the antenna 180° and try again.
If you have obstructions such as trees that can't be avoided, a larger antenna may be indicated.
Old 4-Dec-2013, 11:05 PM   #3
Looking at the , Digital Current Plus Pendining Applications Included Radar Report and Channel List.
For reception of the Digital Broadcast Tv stations/channels in the Green reception zone and down to and including in the Yellow/Red reception zone , WKFK-LD channel 13 , www.en.wikipedia.org/wiki/WKFK-LD .
Above the Peak of the Roof in such a manner that the roof and building are not , obstructing , impeding , blocking , reception in the directions of , South West , West, East .
Aim a , www.antennacraft.net , HBU33 antenna at about 254 degree magnetic compass direction.
A antenna system amplifier will most likely not be required.
Buy the HFS splitters at , www.solidsignal.com .
www.ronard.com/909911.html
www.ronard.com/34424560.html
www.ronard.com/ychim.html
Buy the ronard antenna mounts at , www.solidsignal.com , by typing , ronard(x) , in the solidsignal search box or buy from , www.ronard.com .
www.solidsignal.com
www.amazon.com
Last edited by teleview; 5-Dec-2013 at 5:34 AM. Reason: Clarify information and typos.
Old 4-Dec-2013, 11:19 PM   #4
fkgrable@aol.com
Thanks for your help
