Old 5-Nov-2013, 5:58 PM   #1
nocraig
Suggestions
http://www.tvfool.com/?option=com_wr...46aecca8dc5ad5
http://www.tvfool.com/?option=com_wr...46ae301dcbe629
Looking for recomendations to receive as many channels as possible to the north and the south. Preferably without a rotor. Will have trees at a 25 ft and higher with roof top placement in each direction. Could possibly mount at 10-15 ft and miss the trees.?? Looking to run 3 TVs and don't have any equipment.
nocraig is offline   Reply With Quote
Old 5-Nov-2013, 6:59 PM   #2
Pratical and Useful Information.
The Current Tv channels that are being transmitted and received in the
USA , Canada, Mexico , are
VHF low band channels 2 thru 6
VHF high band channels 7 thru 13
UHF band channels 14 thru 51
Your location has receivable channels in All 3 Tv channel bands.
Recommend install a Channel Master CM5016 All Channel antenna for reception of as many Tv stations/channels as possible to the , south and north , with the CM5016 antenna aimed in 1 direction , about 170 degree magnetic compass direction.
The signal strengths are strong at your location.
Test reception without a antenna system amplifier.
Test reception with a Winegard , LNA-100 'Boost' amplifier.
Test reception with CM5016 antenna low to the ground.
Test reception with CM5016 antenna above the roof.
www.channelmasterstore.com
www.winegarddirect.com
www.solidsignal.com
www.amazon.com
As Always , trees and tree leave , plants and plant leaves , have a Negative Effect on Broadcast Tv Reception
Absorbing , blocking , Reception
Multi-Path reflecting signals bouncing around
And so do buildings and other obstructions including your own roof and building:
The Best Pratice is to install the antenna at a location that has the least amount to no amount of obstructions of any type or kind in the directions of reception including your own roof and building.
The Tv/s Must Channel Scan for the , OTA=Over The Air , Digital Broadcast Tv stations/channels , often named the , DTV Channels ~ Air Channels ~ Antenna Channels , in the Tv setup Menu because the Tv transmissions travel through the Air from the transmitting antenna to the receiving antenna.
Some digital Tv's / digital tuners , will Automatic channel scan for cable Tv channels.
DO NOT channel scan for cable Tv channels.
Go into the Tv Setup Menu and select , DTV Channels ~ Air Channels ~ Antenna Channels .
AKA , ATSC channels / 8VSB channels .
Scan for channels.
Digital Tv tuners can develop -Digital Glitches- that are not cleared out with simple channel scans.
Do Double Rescan , www.wchstv.com/DoubleReScanAlert.pdf
Last edited by teleview; 6-Nov-2013 at 4:57 AM. Reason: Clarify information and typos.
Old 6-Nov-2013, 4:11 PM   #3
nocraig
okay thanks, Just to clarify this will work at for both north and south withough antenna rotation.
Old 6-Nov-2013, 7:05 PM   #4
Yes , to receive as many channels as possible to the South and North with 1 antenna aimed in 1 direction with no antenna rotation , install the CM5016.
As you stated , you think you can install the antenna at 10 to 15 feet above ground and miss the trees.
Meaning the main bulk of the tree limbs and leaves , and have the tree trunks in the directions of reception.
Yes you can install the antenna down low and see what reception is like.
Last edited by teleview; 6-Nov-2013 at 7:24 PM. Reason: Clarify Information and Typos.
Old 6-Nov-2013, 11:26 PM   #5
So that no one thinks that vegitation such as and not limited to , trees and tree leaves , plants and plants and plants leaves , do not have a negative impact on broadcast Tv reception.
Here is the Clear Truth
Trees and tree leaves, plants and plant leaves , have a Negative Effect on broadcast Tv reception
Absorbing , Blocking , Tv Reception
Mult-Path Reflecting Tv signals bouncing around off the , trees and tree leaves , plants and plant leaves.
